SOURCE: I have an older Airens
PUNCH IN YOU MODEL TO GET PARTS DIAGRAM, MIGHT HELP YOU.
http://partsradar53.arinet.com/scripts/EmpartISAPI.dll?MF&app=ARNC531&lang=EN&TF=Empartweb&loginID=ariensc&loginpwd=consumer&partner=ARNC
SOURCE: ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
SOURCE: I have an Ariens 1128
Hi, I will try to help you with this problem. I think the problem might be an adjustment issue. If you take the cover, usually plastic, situated just in front of the engine housing, you will see the belts and pulleys. Without the engine running, press on the auger/impeller lever, and if you look inside you should see how the belt is made to engage the auger pulley. Probably by an idler pulley that pushes on the belt to make it tight to turn the big pulley. That is the most popular way, it is to loosen the bolt on the idler pulley and push it towards the belt so it applies more pressure to the belt to turn the auger pulley and tighten the bolt. There could also be an adjustment on the linkage that might be adjustable. Another possibility is that the belt is worn and is riding on the bottom of the pulleys therefore not providing enough friction to turn the pulleys properly. I think if you take a good look at that system you will comprehend it. Hope this is helpful. All the best and good luck. I will gladly answer any other questions.
SOURCE: installed auger belt on my
Sounds like the auger belt is too tight. What belt did you use? Toro 37-9080? If you used the right belt, there is an adjustment on the cable going to the pulley that pulls the belt. Follow the cable to where it goes into the side of the machine. There should be an adjuster. Loosen the adjuster so that there is enough free play so the auger does not turn when the handle is not pulled.
SOURCE: Snowblower bolt stuck between frame behind back of
Rust penetrating oil. you may have to resort to Heat
