I want to connect Garmin transducer with it and make a new power cable because I lost old one. I dont know which pins in connector goes where when connecting cables.
Here is the link to the owners manual.It has a copy of a wiring diagram.Not sure if it is the one you are looking for but maybe someone else may be able to use it if not. Hope this helps you with your project
Good Luck
http://www.navmanmarine.net/upload/marine/internet_manuals/eol/4100_4150_eng_web.pdf
Testimonial: "I have this manual already, but I need wiring diagram where is shown which pins mean what. There are two sockets and bouth have 8 pins."
This manual I have already. But I need wiring diagram , where is shown which pin means what. There are two sockets and bouth have 8 pins.
Here is a link that may help you in what you are looking for. If this one doesn't help I am out of options.Good luck. .......http://faq.airmar.com/index.php?action=a...
I put in a message to NAV/NORTHSTAR to see if they can send me a full set of the diagrams but up to now they sent me a copy of the owners manual. If thy send me the diagram I will post it.Also if you google Navman/northstar wiring diagram it shows a few more diagrams that might be helpful.
Black is ground,there are 2,use either.Brown is not used.White is NMEA out. Blue is your NAVBUS.negative. Red is power in 10.5-30.5VDC. Orange is NAVBUS+, YELLOW IS AUTO POWER IN Green is external alarm out 30 V DC 200 mA MAX. These are the power cord pin colors.They are in pin order. Pin #1 is at 11 oclock on the fish finder and then runs counter clockwise.Hope you are all set.
Can I connect a Garmin transducer with my Navman Fish 4150? I have wiring diagram where is Navman connections and Garmin also. But how and which cables going wher if I connect the Garmin transducer? I add some diagrams where is Garmin and Navman connections, maybe You can explain me. Or they are same , so I can plug straight the Garmin transducer to my navman. And do I understand right, that power cable goes to up and transducer cable down socket. I am asking this because bouth are looking similar???
On that picture is one navman, not exactly the same what I have , but is the power cable up?
Send an email directly to the customer service department and explain what you are trying to do and what kind of equipment you have and are using.Here is the email [email protected] . Please let me know if they are able to help you out.If not I will start my search again.I will try to help you as much as I can.
Tell them you need the power cable pin diagram for your model. Doing it that way you have the best possible diagrams for the work you are trying to accomplish.George
Hello, They give me this answer: I do not have the pin out for the old Navman 4150x. Only the transducers made by Navman would work on Navman products and not other brand of transducer will work. The electrical hardware and software does not allow for another manufacture's transducers to work. Tom Thank you for choosing Navico products!
Add a CommentBut I have read that people have mixed the transducers and fishfinders with each other. Or maybe is it so with this one that only navman transducer fits. One more thing , do you have Navman transducer wiring diagram?
Hello , I have a new question. How I connect fishfinder transducer wires and speed sensor if there are 4 wires bouth? I dont know what the colors means. The transducer and speed sensor have bouth 4 wires and same colors : black, white , yellow and blue. What color means what? only number I found was 5,109,364;D329,615 ( Lowrance I guess)
