My Frigidaire Affinity dryer just started beeping in the middle of the night. It wont stop beeping. I ran it once to try and make it stop and it worked for about 10 minutes then shut off and continued beeping. The beeping random with no error code and after the first time it no longer heats. I have unplugged it and plugged it back in. Every time I run it now there is no heat, it's beeps the whole time (it's the dampness setting lights flashing (making this beeping noise)). Then after about 10-15 minutes it shuts off.
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
