SOURCE: My galaxy tablet was fine
You can damage the battery but it is very rare to actually do that. What you need to do is plug it in to the wall charger and leave it alone over night. At that point it should be just fine. it will actually start to show some signs of life after a few hours but don't be tempted to do anything wih it. it will first show a charge light or something after maybe 40 minutes if it is a faster charger.
If it shows no life the next day then you can try charging again but at this point you may hae a problem that requires either a battery replacement or warrenty. The battery has a microcontroller on it and when the battey gets real low they do not behave that well and typically you get the stone dead brick behaviour. And most people do not let it charge long enough to get it working. It is possible that there are other problems but those are usually moore serious and require replacement of the unit. The battery can be replaced but requires the etire case to be disassembled.
So charge it then check your warrenty and it may need serious repairs or to be replaced. If it is out of warrenty then you need to be careful on the cost verses replaceemn
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
