Seems like faulty wire move head up and down by hand and power and light stop working
SOURCE: Power head stops and starts
The problem is with the connection between the flexible hose and the handle - there is a joint between the two that allows the flexible hose to rotate in the handle and the electrical connection here is not great!
If the head stops working you should rotate the flexible hose at this joint (i.e. where it joins the handle) and you will see that the head unit will start to work again.
Not sure what a long-term solution would be - probably to clean this connection, grease it again with white lithium grease, and perhaps to bend the spring connection here so that it makes a reliable connection again.
No Owner's manual? Try manualslib.com
But wild guess is the filter bag or possibly the secondary filter is
full. Sometimes. the effect of the full bag will pop open the latch for the filter bag and as a result, will automatically stop. Otherwise, it may be that the motor has overheated as a result of the full filters and stopped due to the overheating.
