Pushed button on top but it won't release other beater. How do I remove it?
SOURCE: The release button to raise
Put a few drops of cooking oil in the holes the the beaters are inserted inMake sure to unplug the unit. Pushing the button, work the beaters pulling lightly. Good Luck
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
