Get a copy of the Repair Part List for your model at Kitchenaid.com
Constant pushing of the beater onto the Agitator shaft (40) can cause
it to be pushed in too far into the Planetary (33). With the beater in place,
use a rubber mallet to slightly tap the edges of the beater and push the
shaft out until you can see the retaining clip.
Now you have enough clearance on the shaft to push the beater upward
and twist it to remove it.
Put a few drops of cooking oil in the holes the the beaters are inserted inMake sure to unplug the unit. Pushing the button, work the beaters pulling lightly. Good Luck
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
I had this same problem as well. The beater was stuck like glue to the rotating arm, and it would not budge with any amount of pressure. I tried the cooking spray and it did nothing. But today I put a rag in hot/boiling water and then carefully wrapped it around the top of the beater. I let it sit for 10 minutes. Then I put the rag in hot water again and repeated the process for about another 5 minutes. When this was done, I covered the beater in a towel (to protect it) and forcefully tapped (ok... I pounded) it with the flat side of my meat tenderizer (it was all I had...you could use a mallet or hammer). It took a little bit of work because I had to hammer it from the bottom, then the side, then the top to get the little spoke guided through the shaft. But it did finally come off. After cleaning with hot water, I put the beater on again and noticed that it was still a little hard to get on/off. So, I put a little bit of veg. oil on it, and it seems to be better. Going forward, I will be sure to clean the top of the beater & arm after each use and then coat it with a little oil to keep from sticking. Best of luck!
The beaters can be retimed but, you have to open the mixer. There are 2 gears visible inside the head. Look closely for arrows or dots on the gears. These are the timing marks. Like marks should be placed exactly opposite each other on the work gear. (The spiral shaped gear) Look at the notches where you put the beaters. One will be lined up straight, the other will be at 45 degrees. While you have it opened, you might want to regrease it. Remove the old grease with a stick or small narrow screwdriver. Put vaseline or equivalent in the gear area. Only fill it about half way. If you over fill it, it will leak out when you get it hot from long or heavy use.
Try turning the beater in the reverse direction to the direction it normally turns - clockwise looking at the beater (I think), this should make the shaft pins ride up on some cams which should release the beater.
