Question about Watches
How do I use the buttons in this QHY watch?
Men Round Dial PU Band LED Digital Multifunction Sports Wrist Watch 30m make shhors looking for a manual
    Problem Solver:
  • 18 Answers
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Posted on Dec 06, 2014
SOURCE:
  • 40 Answers
SOURCE: versace watch
call an authorized retailer in your area and they will be able to order a band for you. Here is a link for the website http://www.vertime.com
Posted on Feb 09, 2007
SOURCE: Invicta 2875 wrist watch band too large
http://www.geocities.com/watch_crazy/bands/bands.htm
Posted on Jun 30, 2008
  • 9 Answers
SOURCE: watch band for shark freestyle model 788
You can call 888-222-5230 x502 Customer service. The band was $12 plus $3 shipping.
They will need your watch model. Shark Mako 788 (01)
Web site is www.freestyleusa.com
This is through Geneva Watch Group NY
Other post lists old extension (Linda works in another department now).
Posted on Jan 07, 2009
escapement
  • 2338 Answers
You may or may not have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: how to adjust metal wrist band on casio watch?
  1. Pop out one spring pin to disconnect the band from the watch or from itself at the clasp. If you don't have a special tool for this, a needle or a pin will probably work. A straightened paper clip may be too thick, but they are cheap so you could try it. Now the watch and band can sit flat on the work table.
  2. Examine the links. If some of them have little arrows on them (usually the ones closest to both sides of the clasp), they are removable.
  3. These removable links are held together by a "U" shaped (actually a squared off "U" - sort of like this |_| ) pin that is inserted into the link. There may should be some kind of window-like opening in the link into which you can insert a narrow screwdriver or similar tool or even a small nail (around 6-penny size) and push out the |_| shaped pin. A straightened paper clip is probably not sturdy enough, but you could try it. Push in the direction of the arrow (from tail to point). The links that were joined by the |_| pin can now be separated.
  4. Remove a second such pin from another adjacent link. Now a single link is free and can be discarded (or kept). Reconnect the remaining adjustable links with one of the |_| pins and re-attach the spring pin from step 1 so the band is reunited with itself or with the watch.
  5. Try it on. If it is still too long, repeat the process. Good luck.
Posted on Mar 24, 2009
How to change date on shhors digital watch
Use the S button on the lower right to cycle through the minute, hour, date, month, and day of the week, and use the D button on the upper right to change those things. Push the M button one more time to get back to normal operation. To set the alarm: Setting the alarm is the same as setting the watch.
Amazon.com: Customer Reviews: SHHORS Sports Water Resistant ...
https://www.amazon.com/SHHORS-Sports-Water-Resistant.../B00WDPZWYY
shhors digital watch instructions - Google Search
Apr 08, 2017 | Watches
How do i set the day ? Mine is stuck on sun.
I would try removing the battery for 10 minutes reinstall the battery if it doesn't help there's a problem with the circuitry.
Hope it helps thank you.
Jun 10, 2015 | Novelty 30M Waterproof Analog & Digital...
Burberry sport watch, rubber band "thing" that keeps band up against wrist snapped.
Great blog, thanks for sharing! http://www.ttoffice.co.uk/
Dec 14, 2012 | Burberry Watches
Replace wittnauer wrist watch band
Looking for men's Wittnauer gold stainless watch band for JV 8243 Swiss 9544.
Please advise if you know where the are available.
Regards,
Steven Foxworth
sfoxworth1@comcast.net
Apr 10, 2012 | Wittnauer 10D02 Montserrat Watch for Men
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
Versace watch ( wristband)
Same place where you bought the watch, mate, same place where you bought the watch. Surely the watch is a Versage but the wrist band can be any band you can find at any good watchmaker of jeweller. ;)
Sep 23, 2009 | Versace 27473-008-00 Wrist Watch
Watches Logo
944 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
