Question about Linksys Wireless-G WRT54G Router
Postoffice router to skybox so ican usemy catch channel
My router is amg1302
How do I tune my TV in the kitchen to my Sky box in another room.
Sky box stuck in Stand By on red light Sky Box Guides faq
Sky Troubleshooting faq
either you have it hooked up wrong or skybox doesnt allow 2 screen use,you may need another skybox
May 14, 2015 | Televison & Video
Can you watch the same sky channel on 2 tvs
Yes if you use the rf2 out on the box, cable it to the aerial input of the tv in the other room using uhf coax cable (aerial cable), and tune the tv in analogue mode (not freeview but the old analogue) to the sky box. It's usually on CH68 but if you do an autotune it should find it. Of course you will only be watching in SD not HD on the second set.
Jun 19, 2014 | Computers & Internet
Cant connect samsung phone to router
maybe the password of router is not match in your phone try to config again your router and change your password setting to wap
Apr 01, 2012 | Android Galaxy Ace
Hi I've recently bought a UMC 40" TV (model: M40/74G-GB-FTCU-UK) and everytime I try to tune it, it just says there is no signal and no channels are found. Everything is connected as it should be....
strange it sounds like there could be more of an issue with the skybox but if you have any RCA cables plug them in and use AV1 or AUX on the tv set however if it has HDMI then plug in a HDMI cable to and from the skybox otherwise check on the back of the skybox and see if there's a channel the TV must be set to
Aug 22, 2017 | Televison & Video
The box keeps searching for channels
hello,silly question is the aerial connected, also if you've got s skybox make sure it's connected i'e the aerial is in the skybox and a lead from the skybox to the tv
regards
shaun
Oct 24, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Secutiry issue
You will need to access your router and configure your wireless settings. If you are uncertain about the password/username to access the router 0 then you might find it on label at the backside of the router.
Failing this - the favourite combinations are :
Username admin
Password admin
or sustitute "password" (without the quotes) as the password. If that does not work then you could "google" the question.
Feb 20, 2009 | Zyxel Prestige 600WH Wireless Router...
Error 158
FDirSync: Err Msg: Error [158] Requestor Not Registered View products that this article applies to. function loadTOCNode(){} Article ID : 99268 Last Review : October 30, 2006 Revision : 1.1This article was previously published under Q99268 SYMPTOMS loadTOCNode(1, 'symptoms'); When a Foreign DirSync, Directory Synchronization with Foreign Mail Systems, message comes into the DirSync directory server, these error messages may appear:
In DIRSYNC.LOG: "3/23/93 11:00:03 | Error [158] Requestor not registered :
PCM:" -or- "3/23/93 11:05:03 | Error [158] Requestor not registered : PCM:NETWORK/POSTOFFICE" In ADMIN's Mailbox: "Requestor not registered :
From: NETWORK/POSTOFFICE/USERID" CAUSE loadTOCNode(1, 'cause'); If the NETWORK/POSTOFFICE are a foreign DirSync postoffice, one of the following may cause the error: • The NETWORK/POSTOFFICE was not defined on the directory server using ADMIN:CONFIG:DIR-SYNC:SERVER:REQUESTORS:CREATE. Without this, the directory server does not accept requests from a requestor. • The REQNAME field in the DirSync message has a typo for the NETWORK/POSTOFFICE name or the directory server has a typo defined for the FFAPI gateway postoffice. • The REQNAME field does not contain a NETWORK/POSTOFFICE. For example: REQNAME=PCM: The Directory Synchronization with Foreign Mail Systems Manual does not clearly explain the need for the network and postoffice name for Microsoft Mail Software Development Kit (FFAPI)-based gateways. Other gateways require only an entry containing one of the predefined types. These types are listed in the "Foreign DirSync" manual. APPLIES TO • Microsoft Mail for PC Networks 3.0
Jun 25, 2008 | Audio Players & Recorders
BEV Coolsat Dish problems
Has the position of the dish been changed ie by the wind?
Sep 04, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
85 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
