What is a pixel anyway what do u do or what do i go to on the sansui244 to get split screen so 2people can play minecraft we have xbox360 hooked to the tv it comes on but don't know how to get split screen PLEASE HELP im sooo sorry
Minecraft Xbox 360 is a multiplayer game by default. Players can join online or locally via connected controllers. Split screen is a way to play multiplayer on the same console. To play split screen, the Xbox must be outputting a resolution of 720p or higher.
you must have an HD TV for split screen. Connect Xbox to tv with an HDMI cable. Start mine craft when you've logged on with your first controller enter your desired world then pause the game. Turn on and sync your other controllers if they haven't been connected before.Log in those controllers and press Resume Game.
SOURCE: How to hook up additional speakers to the TV
If you have a surround sound system, (amplifier and speakers), run the DVD speakers out wires to the amplifier IN. Thi way, you don't even need the TV speakers.
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
SOURCE: Samsung plasma red fuzz on black screen
Most likey its a bad panel, you can try adjusting VS voltage on Y main board, if this is to complex you will need a tech
