Question about Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz
I have samsung un46D6000Sf will not come on No Lights are on when pluged up
I replaced power supply nothing
  • Samsung Master
  • 3,388 Answers
It sounds like an internal electronic failure. If you are lucky it may still have some warranty. Check with the place you purchased it, they may be able to warrant it or repair it. This is not a DIY project unless you have the equipment necessary to do the repair.
Posted on Dec 06, 2014
SOURCE:
Can I interchange a 20 pin wire to 16 to 14?
You need the correct board when ordering replacements you need to quote all the numbers on the original often on a separate sticker on the board as there are often many versions with same board number
Feb 11, 2016 | Samsung Un46d6000 46 1080p Led Tv...
TV picture is dark but has sound, did flashlight test and can see a faint picture.
Usually means inverter or power board is bad! Check power board for voltages. Voltages are usually printed on the header port. if Inverter is bad panel would need replacing. If TV is less than or equal to 12 months contact Samsung for warranty repair.
Oct 19, 2015 | Samsung Televison & Video
Samsung un46d6000sf now has no picture/ no sound backlights are on. had sound, placed tape on ribbons with left improving then when applied to right lost all, removed tape still nothing???
Hi Kevin,
That happens many a times. You try to rectify one thing, the other one pops up. In this condition, please let a good local TV tech handle your set.
Good Luck.
May 31, 2015 | Samsung Televison & Video
My samsung 32'' lcd tv
poke it open, you'll find bloated capacitors at power supply board. biggest one, with power cord pluged into. replace with thesame value(s).
you good to go!
don't lie, next time! your set has been acting up fpr a while, before it quit. Remembering: few attempts to turn it on, then it works!
good luck.
Apr 04, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My color wheel apparently went out so i had a tech replace. when i got it back it worked for a few hours and the turned off and flashed the 3 leds. so i figured it blew the lamp. replaced that. still...
ballast or smps board (power supply board) or the main board. Had same problem, replaced lamp, ballast and power supply, worked for 2 weeks now front lights flashing again. ordered main board per samsung tech. support.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung UN46D6000SFXZA 46in Led Hdtv 1080p 120hz Logo
56 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
