Question about Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media
My attached 8 gb Kingston in neither opening not formating by window? Pleasse help me to format my usb
My attached USB Kingston 4 GB is neither opening nor Formating, if I can be helped, either to open it or to Format it for my further using it. Thanks
    Master:
    Sergeant:
  • 401 Answers
CIRCUIT PROBLEM....REPLACE WITH NEW ONE
Posted on Dec 20, 2014
5 Suggested Answers
SOURCE:
  • 10406 Answers
SOURCE: My kingston 8gb cards only show 1.87 gb and will
The 'FAT' file-system uses 16-bit arithmetic, and thus is limited to about 2GB in size.
The 'FAT32' file-system uses 32-bit arithmetic, and thus can easily format an 8GB device.
So, be sure to choose 'FAT32'.
Also:
Click Start
Right-mouse click My Computer
Choose Manage
Click Storage
Click Disk Management (local)
Does the card show a 1.87GB "partition", plus 6.13GB of "unused" space?
If so, then delete that "small" partition, and then create a new partition that "spans" the entire 8GB.
Then, FORMAT that partition.
Posted on Nov 27, 2009
laikexpert
  • 281 Answers
SOURCE: PEN Drive Prob
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 02, 2010
rcw1962
  • 2571 Answers
SOURCE: I made partition in my Kingston 4 GB USB and one
Probably best to copy all files off and reformat it.
It would have made more sense to use folders and not partitions.
You may not be able delete the partition if you cant open it.
Does it show up in disk manager?
Posted on Jul 22, 2010
parasgumbhir
  • 179 Answers
SOURCE: MY 32GB KINGSTON PENDRIVE IS
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chipcorruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Posted on Jan 15, 2011
Try another computer. If it does not format then it is defective. Get a new one.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kevin_c38b47f462e94458
Dec 06, 2014 | Kingston 2PK 4GB USB 20 DATATRAVELERI GEN...
Kingston Data Traveler 2.0 64 GB USB - file system corrupted - need to work on windows XP- Upon formatting the pen drive It shows that it has become a raw drive - wat is the file format for the USB to work...
Theoretically, you can't format a more than 32 GB drive with FAT/FAT32 file system. In your case you have to choose the NTFS file system to format your 64 GB USB flash drive. However, if you really need to format it with FAT32, you got to use the command line or a third party tool. Hope this is going to help you.
Apr 06, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I have a 4 GB kingston datatraveller 120 pen drive
I would say do a firmware wipe but seeing as you have no access to the drive at all I would say your probably SoL and in need of a new drive
hope this helps
Robb
Apr 26, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Try re-formating the Pen Drive. Also check your USB and HUB drivers in Device Manager
Apr 26, 2010 | Computers & Internet
Can't read Kingston DTI/4 GB flash drive
you have to see in witch format is the stick mostly is FAT32 but normaly you dont need to format just when is some video on it,from my experience reinstal the drivers and i mean all.
Nov 04, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Can't Reformat Kingston DataTraveler 2.0 USB memory stick
Use any linux bootable distro, like puppy (100 MB ) Slax ( 200 MB) or ubuntu to make a live boot, or use any pc which has linux installed can format your USB to its full capacity.
Apr 20, 2009 | Electronics - Others
Kingston 2PK 4GB USB 20 DATATRAVELERI GEN 3 TWIN PK DTIG34GB2P (740617175851) Media Logo
85 people viewed this question
Top Kingston Electronics - Others Experts
WTF Chuck.....
WTF Chuck.....
Håkan Sterner
SANDIP MISTRY
SANDIP MISTRY
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
