New buttons.
SOURCE: I'm having trouble setting the
It could be that the contacts need some cleaning. Turn the power off and then repeatidly press the buttons. This action may will clean the contacts. If this doesn't work then a new timer from espares is about £80.
SOURCE: Will not stay on!!! the timer unit has the A
You need to check that when you turn the automatic off, there is no time remaining in the cook time. You need to ensure that this is set to zero when cancelling the auto function.
If this still doesn't worh then espares will be able to source a replacement clock for you.
