Question about Yakima SkyBox 21 Rooftop Cargo Box
How do I adjust the latch on my old Yakima skybox 21?
Screwdriver prying and drilling the rivets out
How to fix a door latch on a 1994 nissan pickup
I just joined 10 minutes ago.........I think I can help you.
Use a spoon or wide screwdriver to pop the plastic rivets that hold the interior of the door on. Takes some courage as they dont come away easily, about 8 in all.
1, Remove the window winders, by either pushing the "ring" that touches the interior till it stops and then slide the winder off the toothed stub.pop the cover off and use screwdriver/socket to remove winders.
2, Use old eating knife or wide bladed screwdriver around edge if soft interior of door and pry/pop the hidden plastic rivets, releasing the soft interior away from the metal or the door.
3, You may have to twist off the latch, just like a bottle cap.
4, You will see the wire coat hanger type metal that connects to the latch and locking mechanism.
If you have some grease with you you can also grease up the mechanisms for the lock, lock release, window, mirror.
That's how it is on my Volkswagen.
Good luck, Dave
Apr 02, 2013 | 1994 Nissan Pickup
How do I open Yakima Skybox Pro Cargo Box without the key
How can I open a Yakima without keys. I lost my keys..
Mar 12, 2012 | Yakima Skybox Pro Cargo Box
Exterior door handle on 97 thunderbird
You will have to remove the door panel. To do this use a phillips screwdriver and remove the two screws under the inside door handle. Then lift and remove the section. Remove another screw from the interior lower left corner. Pry the window crank apart "if exists" then use a T20 torq bit to remove the screw in handle. Remove the panel by lifting and pulling at same time. With window in up position you can see inside the hole a rod going from the door handle to a bracket with a Yellow clip. Slide the clip to the open position and pull the rod out of the clip. From the outside of door under the handle there are two rivets. Use a punch and knock out the center of each rivet. Then use a 1/4" drill bit and drill out the rivet. A flat tip screwdriver will be used to knock off the rest of the rivet. You will need two flat head screws and lock nuts or to reinstall the handle. Lift out old handle with attached rod. Twist rod as you pull to remove it and install it into the new handle. Place the rod through the hole and look inside to be sure is will move to the location of the yellow clip.Install the screws from the outside and the nuts from the inside and tighten. From inside connect the rod to the yellow clip. Lift on the rod while closing the clip. Then test door handle. If it doesn't work properly the rod was not lifted or pulled outward enough. Redo that step until you get it right. Reinstall inner panel as removed.
Feb 26, 2012 | 1997 Ford Thunderbird LX
The top won't open. First one side began to stick on the left front ball latch and now the right side won't open at all. Is there a simple solution? Should I sand down the ball on the left side? Can i buy...
When mine did the same thing, I just sprayed each mechanism with some spray lubricant to free it up, worked great. Same in the latches. WD-40 to the rescue.
Dec 30, 2010 | Yakima Skybox Pro Cargo Box
I need to replace the batteries but I can't get the old batteries out of the screwdriver. I've pried and pried and the pack is part way out.
buy some Johnson&Evenrude lubricant (marine) .Spray up into the cylinder. then use vice grips to pull the battery out. Maybe wedge a nail into the push prongs to hold them in.
Oct 21, 2010 | Black & Decker Pivot Plus Cordless...
Instructions to replace door lock assembly
Hello,(1)Open the door and remove the two screws in the door lock latch plate on the edge of the door by backing them out with a Phillips screwdriver in a counter clockwise direction.
(2)Remove the two screws (located on the interior lock face plate)holding both halves of the lock assembly to the door by backing them out with a Phillips screwdriver in a counter clockwise direction,pull each side of the lock assembly from the door,using a flat blade screwdriver to pry them off if needed. (3)Pry the latch bolt out of the door by inserting the edge of a flat blade screwdriver under the latch plate on the edge of the door.slide the latch assembly out and set aside.(4)Insert the new latch assembly into the hole left by the old latch bolt.Trim the recessed opening with a sharp chisel if the new lock latch plate is larger than the old latch plate.Secure the latch to the door with the two screws provided by turning them in a clockwise direction with a Phillips screwdriver.(5)Hold both side of the new lock assembly to the holes in the faceof the door.Line up the shaft from the lock cylinder into the slotted hole in the latch assembly.Make sure the lock face plate with the screw holes is facing the inside.Attach the lock assembly to the door by turning in the screws with a Phillips screwdriver in clockwise direction.(6)Remove the old striker plate from the door jamb by backing out the two screws with a Phillips screwdriver in a counter clockwise direction.Install the striker plate that came with lock kit with the screws provided using a Phillips screwdriver in clockwise direction.
(7)Close the door and test the operation of the lock from the inside and outside using the turn lever and the key.Make adjustment to the striker plate if needed by removing the holding screws.Reposition the striker plate and replace the screws
Thanks
May 26, 2010 | Ovens
Rear door on driver side won't open,have taken the panel off the inside of car,seems like the lock won,t travelas far as it does on the other door.is there any way to open this door,thanks[1997 lincoln...
Rear
Removal
  1. Using a small screwdriver, remove the screw cover from the armrest of rear door trim panel (27406).
  1. Remove the two retaining screws.
  1. Using Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry rear door trim panel from door inner panel.
  1. Disconnect electrical connectors.
Installation
  1. Position rear door trim panel on door inner panel, aligning two locators on rear door trim panel. Reverse Removal procedure.
------------------------------------------------------------------------------------ Rear
Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05 .
  1. Check all connections of remote control links and cables. Service as necessary.
  1. Remove remote control assembly.
  1. Remove door latch remote control assembly from latch assembly.
  1. Drill out rivet at bellcrank and link (264B14).
  1. Remove three screws attaching latch assembly to door.
  1. Drill out rivet that attaches actuator motor to door.
  1. Remove latch assembly with actuator motor and door latch control rod lever link assembly.
Installation
  1. Install new bushings and clip onto latch assembly.
  1. Install latch with links and power lock actuator into door cavity.
  1. Position latch assembly to door, aligning screw holes in latch and door. Install three screws. Tighten to 10-13 Nm (89-115 lb-in).
  1. Attach door latch actuator motor to door with a new rivet.
  1. Install bellcrank and link to door using a new rivet.
  1. Install inside door handle and remote control assembly to door.
  1. Open and close door to check latch assembly operation.
  1. Install watershield and door trim panel. Refer to Section 01-05 .
Item Part Number Description 1 221A00 Door Handle to Door Latch Actuating Cable 2 26446 Rear Door Control Rod Retainer 3 377901 Plug Button 4 26412 Rear Door Latch 5 W623451-S2 Push Nut 6 224A32 Counter Balance 7 22450 Door Outside Handle Tension Spring 8 W701210-S309 Screw 9 224A20 Outside Door Handle Anti Rattle Pivot (2 Req'd) 10 22404 Door Handle 11 224A24 Front Door Outside Handle Spacer (2 Req'd) 12 264A64 Rear Door Actuating Rod 13 22408 Outside Door Handle Anti-Rattle Bumper 14 22428 Outside Door Handle Large Pad 15 N621906-S2 Nut (2 Req'd) 16 N807329 Screw (3 Req'd) 17 26595 Rear Door Electric Latch Actuator (RH) 18 W701566-S47 Rivet 19 431C04-A Rear Door Latch Striker Assembly 20 — Door Lock Striker Plate (Part of Door Shell Assy) 21 W525172-S Rivet (2 Req'd) 22 264B14 Bellcrank and Link (RH) 23 264A50 Bushing 24 N802034-SG Rivet 25 26420 Rear Door Latch Control Rod Link 26 W525172-S Rivet (2 Req'd) 27 21818 RR Door Latch (Inside) 28 A26460 RR Door Latch Push Button Rod 29 21982 Door Latch Rear Striker Assembly 30 N808377-S101 Screw (2 Req'd) 31 250A04 Rear Door Catch 32 N801010-S100 Truss Head Bolt (2 Req'd) 33 N804234-S2 Screw 34 266A74 Rear Door Latch Actuator Retainer 35 24630 Rear Door 36 26552 Rear Door Latch Control Escutcheon A — Tighten to 21-29 Nm (16-21 Lb-Ft) B — Tighten to 10-13 Nm (89-115 Lb-In) C — Tighten to 7-8 Nm (62-70 Lb-In) D — Tighten to 26-34 Nm (20-25 Lb-Ft) E — Tighten to 3-4 Nm (27-35 Lb-In)
Mar 24, 2009 | 1997 Lincoln Continental
1965 mustang door and window problems
latch may be worn out. If so, you need to replace it. Otherwise, make sure it is well lubricated and that the striker on the pillar is positioned correctly. Make sure that the hinge pins are not worn either or door will mis-align sometimes when closing. As for regualtor, first find one. Changing it is pretty much a take-out, put-in and adjust operation. If regulator is riveted in, drill rivets out and replace with pop rivets or nuts & bolts.
Mar 05, 2009 | 1965 Ford Mustang
Broken Door Handle on 1998 Chevrolet C1500 PU
carefully use a screwdriver or chisel to pry the interior panel off of the door...it's thin, like an upholstered piece of hard board, held on by plastic ribbed push-studs, every so often. Those studs can be pryed out and pushed in to reinstall many times if you're careful but I did manage to break one on my truck. Of course there is also a couple of screws near the door handle as I recall but they are visible. A small piece of triangular shaped plastic must also be popped / pryed off of the forward window area. I'm drinking right now, but I think you may have to drill out a rivet to remove the old handle assembly but it is really easy, just pick a drill bit about the same diameter as the rivet and drill it till it falls apart. Install the new assembly with a pop rivet of your own. good luck
Feb 03, 2009 | 1998 Chevrolet C1500
Yakima SkyBox 21 Rooftop Cargo Box Logo
478 people viewed this question
Top Yakima Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Yakima Boating Expert? Answer questions, earn points and help others
