Cars & Trucks Logo
r
rachel montero Posted on Dec 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHAT IS THE valve clearance adjustment OF ISUZU 6SD1?
I need the valve clearance for isuzu diesel engine 6sd1
Bill Boyd
Level 3:
Top Expert:
  • Isuzu Master 53,816 Answers
  • Posted on Dec 05, 2014
Bill Boyd
Isuzu Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11947253
Points
172802
Valve clearences of diesels if not hydraulic operated will be .012" inlet hot and .014" exhaust hot
What is the valve lash on the 98 Isuzu c240 diesel engine
Engine data : ISUZU C240PKG. GENERAL DATA. MODEL. C240. MAKE. ISUZU. FUEL TYPE. 4 / DIESEL ... VALVE CLEARANCE - INTAKE COLD mm. 0,45
https://www.google.com/search?q=98+isuzu+c240+diesel+engine+valve+clearance
Hello, How does the diesel injector pump for 6sa1 differ from 6sd1? and would installing 6sd1 injector to a 6sa1 engine make it more powerful?
the 6sa1 pump is an inline pump suitable for a turbo charged isuzu engine
the 6ad1 pump is a common rail diesel pump and will not fit the engine as the 6sd1 pump is a pump that just supplies 25,000psi to a common rail into which electronic controlled injectors are fitted
e-bay has a listing for a new 6sa1 pump for $1976.00 ud + $171.38 shipping
search-- 6sa1 and again for 6sd1 diesel pumps and the photos will show the difference
The best solution you'll get from books at www.reliable-store.com
These are books containing info on repair, service, troubles hooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Isuzu 6SD1 engine Crankshaft journal size Mains & Bigends Block Bore size.Engine Bolts and nut Torqs for engine assembling
invest in a workshop manual as you will need it for the assembly procedures
all of the requested details will be in the book
I need conrod bolt torque settings for a isuzu 6sd1 motor
Don't worry I'm sure you will get the solution of your problem, just check the link I
attach
isuzu
Rpm troubleshooting isuzu truck 6sd1-2
an AVALON ISUZU? engine swap?
post car, and year. (if really smart , country, be the first !)
and symptoms. (is this a diesel engine?) do post exact engine type and displacment, or all answers will be wrong./
pretend we cant guess.
4helpful
3answers
Valve clearance 4hj1 isuzu engine
This is the specs for the 4H Diesel engine:
Intake valves clearance cold 0.4mm(.016inches)
Exhaust valve clearance cold 0.4mm(.016inches)
Top Isuzu Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you an Isuzu Expert? Answer questions, earn points and help others
