Sewing Machines Logo
T
Tammy Barreto Posted on Dec 05, 2014
Where can I get a manual for the Necchi omega 6030
We cant get the bobbin to pick up and to sew and the needle looks long Help please
A
Anonymous
Http://sewitup.net/6030.pdf
other manual are here
http://www.manualslib.com/
Hi there I got a Necchi Lydia 544, my needle tread does not pick up the bobbin tread, I follow the instruction manual step by step as well as videos on youtube.
when you put the bobbin in the carrier make sure you have about 6" of thread out
next adjust the needle thread tension right up
I am in dire need of the service manual for Necchi Omega 6030
The following web site is a pretty good source:
http://www.sewingpartsonline.com/needle-threader-singer-503277.aspx
I would like to know if there is a place on line to purchase a foot control for a Necchi Omega 6030 sewing machine for less than $35. And also a free download manual for the Necchi machine
I don't of anyone that has a free manual, try these 2 sites and see if they can help you
sewvacdoctor.com or A1sewingmachines.com,, you can even try ebay
there is a facebook group for necchi sewing machines, you might join them and see if they have a free manual
1helpful
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Please tell me exactly how to thread the bobbin on a 3620. I have followed the instructions, but I don't have a picture showing the bobbin when finished. I start with the bobbin thread coming from left...
I also own 2 necchi sewing machines, I used to have a 3620 myself,,
in my operation manual it has a picture of threading the bobbin case,, if you would like a picture send me a comment with your email address
1helpful
Necchi 215A Sewing machine Could anyone help I have a Necchi 215A which will not catch teh bobbin thread, I have tried a new needle and checked the bobbin is loaded and fitted correctly. The needle passes...
Make sure the bobbin has a 3-5 inch thread tail
Then make sure the top thread has a 3-5 inch tail
Then hold the top thread tail with your fingers (away from the needle)
& use the hand wheel on the right hand side of the machine to slowly
Lower the needle in the bobbin area & see if the bobbin thread will pick
Up that way
Bobbin thread will not pick up
Ensure the bobbin thread is mounted on correctly and using your right hand turn the gear that makes the needle go up and down until it catches the thread.
2helpful
Not picking up bobbin thread
Make sure that the needle is inserted with the flat side to the back and that you are threading the machine correctly. Be sure to turn the handwheel counter-clockwise, from the top towards you.
Top Necchi Sewing Machines Experts
vince
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
