Samsung Galaxy Gear Smartwatch- Retail Packaging - Jet Black Logo
d
daniel Posted on Dec 03, 2014
My galaxy gear wont charge
I have brought a new dock for it and still dont charge the batrey sign comes on for 1 second and then goes of and dont charge
Alex Hernandez
Level 1:
  • Contributor 56 Answers
  • Posted on Mar 03, 2015
Alex Hernandez
Contributor
Level 1:
Answers
56
Questions
Helped
10137
Points
80
Seems like the charging capabilities of the battery have been exhausted.
Try another cable/ac adapter. If same results, you might think of a possible battery replacement
I have Citizen Eco-Drive-Pilot Promaster-radio-controlled, shortly i noticed that the second doesnt move and allways stay in 12 Oclock position. Hakan
When was the last time you left the watch out to charge? EcoDrive watches are basically daylight powered. It can also use light bulb light to charge as well. My first suggestion would be to place it face up somewhere where it will get plenty of sunshine and leave it to recharge. It might take 3 or 4 days if it has gone totally flat but it will cost you nothing to do this. If this doesn't work I would recommend taking it to a good Citizen dealer and see if the watch can be serviced. If you have pulled the crown too hard you could have damaged inside the watch.
A built in feature on some Citizen watches is the '2 second tick'. If the charge is low the second hand will jump 2 seconds at a time instead of one. When recharged it goes back to normal.
Stopwatch of the watch goes to wrong places when reset.
There is normally a calibration position. Try pulling out the center crown and pay with the upper and lower pushers. Do that with the two positions. You can watch this video https://www.youtube.com/watch?v=uVQFjeLYfpI
Sep 15, 2015 • Watches
SAMSUNG Gear Watch not switching ON
try pressing the power button for 3 to 5 secs. If still no power, connect it to a working usb/power source and try to turn on again.
If no sign of power even connected, you might need a battery replacement. A little history on what happened before this will be helpful
3answers
How long will the battery on a samsung galaxy gear smartwatch last?
According to Samsung's site, the battery on the galaxy gear smart watch should last up to 25 hrs.
2answers
My Casio Gw-300 G- Shock watch face intermittently goes blank altogether. Immediately prior, the solar battery shows a full charge, (in addition, the back-light battery is less than a year old). When the...
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
4helpful
2answers
Screw down crown wont lock
There are only two things that can cause screw down crown to malfunction. First is dirt and second is weakened/damaged thread. In first case you need to use ultrasonic cleaner by immersing the crown AND case to get rid of any dirt and grime sticking on both threads. If the matter is weakened/damaged thread - you will have to fit new crown and (possibly) new case tube on which crown is screwed onto. This can be done by decent watchmaker only.
Rate me, plz.
Jan 06, 2010 • Watches
3answers
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
1helpful
2answers
Skipping second hand
i have this problem too... it's for my gucci 5500M. i haven't tried replacing the battery, but i remember the second hand getting this problem when i had to change the time. i wonder if a small gear broke inside the watch, but the weird thing is that the time still stays on time.
Top Samsung Watches Experts
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Watch Expert? Answer questions, earn points and help others
