Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
Electric Fireplace Insert
My fireplace insert does not come on. It could be the switch because I get nothing when I turn on the switch. It worked fine for a year.
    Champion:
  • 233 Answers
Verify the breaker is on (reset) then power up and verify voltage with a meter, there are safty devices that will keep the unit from energizing other than the switch
Posted on Jul 13, 2009
    Top Expert:
  • Leisure Master
  • 19,466 Answers
Check power supply and test switch and components
Posted on Oct 09, 2018
Electric fireplaces enjoy many advantages over traditional wood and gas-burning fireplaces. An electric fireplace insert is cheaper to set up, requires almost no maintenance, and you never have to worry about your home getting smoky. Best Electric Fireplace 2018 Top 15 Reviews Best Deals
SOURCE:
Heat does not work shuts off after ten secounds
ClassicFlame 36EB220-GRT 36" Traditional Built-in Electric ...
www.amazon.com/ClassicFlame...GRT...Electric-Firep...
Amazon.com, Inc.Save Big On Open-Box & Preowned: Buy "ClassicFlame 36EB220-GRT 36" ... TheClassicFlame PRO 36" traditional built-in electric fireplace insert, 240 volt, ... Heatingyour entire home all day may not be the best economic choice for your utility ... Youcan shut off the heated air blown to different sections (or 'zones') of your ...
Amazon.com - ClassicFlame 36EB221-GRC 36 ...
www.amazon.com/ClassicFlame...Electric-Fireplace/.../...
Amazon.com, Inc.
Rating: 4.1 - ‎7 reviews
36\" Builder's Box Electric Fireplace Insert The ClassicFlame builder's box features... You can shut off the heated air blown to different sections (or 'zones') of your home... 36EB221-GRC 36 inch contemporary built-in electric fireplace insert will .... Wedid finally get the pieces after about a month, and the unit is working now, ...
ClassicFlame 36-Inch 120V Traditional Builders Box ...
Jan 18, 2016 | Classic Flame PRO 36EB110-GRT 36 Inch...
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Our fireplace is 22 years old and we are not able to start the fireplace.
Is this a flame effect electric fireplace with a fan heater underneath it?
If it is, the bulb has gone. Remove the coal or logs and remove the cover. You will see the bulb.
Dec 29, 2015 | Heating & Cooling
How do change a bulb in a classicflame 23ef010gaa
How to Change a Light Bulb in your Electric Fireplace
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
FIREPLACE WILL NOT TURN ON
Yes and no......
If the fireplace wont turn on from that switch, Most likley a diffrent switch
Dec 19, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Gas fireplace will not light up
If it has a pilot light, (website says it does) I suspect its the thermocouple. These are easy to change yourself and cheap, you can buy a universal thermocouple and it will be cheaper than a Napolean one. The end of the thermocouple is a fat copper pin that sits poking into a small pilot flame. The heat of the flame on the copper tells the system that the gas is burning ok so it allows more gas through. But after a few years the copper end gets covered in black charring and this slightly insulates it from the heat, so it signals to turn off the gas.
Dec 15, 2013 | Napoleon Fireplaces Napoleon IR3N 24000...
My problem is I have a electric fireplace the insert is a colemen and the heater stoped I bought it a Costco about 4 years ago
It may need repairing, do not take risks trying to fix it without an expert. But its 4 years old so its better to replace it with new.
Dec 15, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Febo Electric Fireplace Insert Using remote It Will Not Auto Shutoff when room reaches temp. also If room is Cold & Temp is set higer it will not turn on. U have to manually shut it if or on. there is...
Maybe its the fireplace's ignition spark box at the bottom of the fireplace, its behind the bottom vents and bought one on line and replaced it, easy as pie. Best of luck
Oct 24, 2013 | Leisure HOMEPRIDE Electric Fireplace...
Vermont casting fireplace vcef33
You could take a table lamp or a drop light a electric drill or anything similar,and see if you can unplug the insert and plug one of these items in and see if the plug works
I am taking for granted that you can get to the plug without having to pull the insert out or at least not all the way out
If you can't do that
Turn the breaker off to that circuit pull the switch out and make sure nothing is touching
Hook a tester to the wires and then turn the breaker on and see
If you have power to that switch turn the switch off and on watch the meter and see if it does turn on and off
If you have power coming out of the switch.
and you can't reach the plug then you only option would be to pull the insert
As for a fuse there may be one but not look like what you are thinking a fuse will look like it is usually a temperature fuse that is shaped similar to a diode the symbol for it can be two ways
it could have what looks like a c laying on its side upright and also another c beside it on its side aiming down like a snake crawling. The other symbol looks like a rocket with no fins on its side with a with a what looks like a T laid sideways coming off one end
Oct 20, 2013 | Heating & Cooling
How to replace my charmglow electric fireplace with a gas insert
Check your local building codes for restrictions. You MUST have the proper exhaust for a gas unit. There may also be flooring and wall requirements that need to be changed.
Jan 18, 2013 | Heating & Cooling
Heating & Cooling Logo
660 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Colin Stickland
Colin Stickland
Craig Butler
Craig Butler
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
