Check the power supply: Ensure that the food processor is properly plugged into a functioning power outlet. Sometimes, a loose connection or a tripped circuit breaker can cause power issues.
Safety interlock system: The Kenwood Multipro 910 food processor usually has a safety interlock system that ensures all parts are properly assembled before it can start. Check if all the components, such as the bowl, lid, and blade, are correctly locked into place. If any of the parts are not properly assembled, the food processor may not work.
Motor overload protection: If you have been using the food processor for an extended period or with heavy ingredients, the motor may have overheated and triggered the overload protection mechanism. In this case, you will need to allow the motor to cool down for some time before it can restart.
Fuse or circuit breaker: Some food processors have a built-in fuse or circuit breaker that protects the motor from electrical surges. Check if your food processor has a fuse and ensure that it is intact. If it has a circuit breaker, reset it if necessary.
Mechanical issues: If none of the above steps resolve the problem, there might be a mechanical issue with the food processor. It could be a faulty motor, broken wiring, or a malfunctioning switch. In such cases, it is advisable to contact the Kenwood customer support or take the appliance to an authorized service center for repair.
black wire indicates negative so if you can see a place on the circuit board that looks like that's were it came from then get some advice from an electronics person before you put it together.
It sounds like your mixer has a bad ground connection. Sorry electrical is not my forte, but something in the mixer wiring is the problem, not the wall outlet..
your motor stator to the commutator is shorting between the copper bus bars and this welding of these bars together from heat constitutes a short circuit and its time to buy a new armature(expensive) or get a new unit and save the old parts
If you can give me a little more information, I'd appreciate it. However, I'm going to give it my best shot to see if I can answer what I believe you're looking for. If you're talking about the outlet (receptacle) that you're plugging your appliance into, then the ground (green) wire, or screw on the bottom of the outlet is where you want to connect your third (ground) wire to. If you just have two wires coming off your outlet (receptacle) and can't find the third wire. Then you'd ground or connect a wire to the inside of the box, and then tie with the ground (green) wire coming from the green ground screw on the outlet (receptacle). The problem with house wiring is, a majority of your older houses outlets aren't grounded. If you have a 3-prong outlet, then maybe yours is. But sometimes, people just change these out for convenience purposes. And lastly, if you're talking about the grounded wire in your appliance - look for a green (ground) screw, otherwise you want to connect this to (or around) a metal screw on the inner frame. A majority of your old appliances were never grounded. So bottom line is; your appliance should work with, or without your ground wire. It would be preferable if it was grounded. But for operating purposes, its not. I hope I was able to answer your question for you. If not, feel free to contact me again. Good Luck, Jim
Hi BGR1,
I am also looking for info for info on a Kenwood Chef A700 which seems to have a motor brush problem if you could help I would appriciate it my email address is [email protected].
Regards Shane
Have recently inherited an old Kenwood Major A707A with same problem, contacted local electrical repair man, experienced with Kenwood mixers. He is fitting a new clutch, will cost about £30. I think its worth it. Anyone out there know where I can get Instruction Manual ?
