Question about Fisher and Paykel Aquasmart wl80t65c
What could be causing is a smell coming out from the back of the washing machine?
Have looked at settings and troubleshooting but can't find anything to help.
    New Friend:
  • 24 Answers
What kind of "smell" ? Rotten eggs, dead animal ? Your water can cause the whole room to stink if you have a lot of sulfur or even a lot of iron in it.
Posted on Dec 03, 2014
    New Friend:
    Problem Solver:
  • 5 Answers
Have you run a "Clean Up" cycle - it is important to do this to ensure your clothes are clean and the machine works at it's peak. If you use it heavily, you should do this every three or four months. You can find this cycle under "Lifestyle" and you should put 1 cup of oxyaction soaker in at the beginning of the cycle and it needs hot water to work. It takes about 3 hours, but is well worth the time.
There is no other real reason for a smell, unless something has died - in which case you should move the machine and remove any deceased animal.
2 Suggested Answers
6ya staff
SOURCE:
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: water not draining completely and causing smell in washing machin
Go to www.washerhelp.co.uk.
Here you will find article on smells in washer, and lots of other useful information, far more than I can tell you.
I think you will find it very helpful.
Please leave feeedback.
Posted on Dec 06, 2008
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
Jun 09, 2013 | Washing Machines
I have a whirlpool cabrio washing machine.ecerything is working fine but its beginning to smell like sewer. The sink next to it doesn't smell nor the drains. It's coming from the washer. Anything I ca
Clear your filter.
Remove detergent drawer and clean the drawer and its receptacle on the machice.
Bung in 8 milton tablets in the drum and put it on the hottest longest wash you can and leave it run normally.
Run a short cold wash to flush the machine
Now put some nice smelling low foaming disinfectant in and repeat the hot wash cycle.
This should sort it but may take repeated treatments. Lower the amount of softener and detergent you use as excess can build up and can cause this problem to come back. Additionally dont overload with really dirty cloths and if you do a wash with exceptionally dirty cloths then after you empty your machine put it on a shortest rinse cycle to purge and contaminated water that is left behind.
If all this fails you will need to have your machine serviced.
Oct 03, 2012 | Washing Machines
Hi my washing machine has started to smell of rotten eggs its only 6 months old and dont no what the problem could be
Possible that the smell is coming from the motor/inlet valve/ pump or the capacitor of the motor. so it is important that you need to have a closer observation to find the source of the smell.
Sometimes it can also be due to drain block and so the dirt accumulation could be stinking. If so remove the drain and clean the hose and fitting , back flush the pump and reset.
check for cleaning on the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Jul 13, 2011 | Hoover Washing Machines
Hi, there is a really bad smell coming from the machine, also i have just done a 60 cycle and the white wash has come out with black marks on, looks like fungus,
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this.
Hope this helps...please post back for further assistance.
Daniel
Apr 18, 2011 | Washing Machines
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Foul odor from front load washing machine
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Nov 06, 2009 | Washing Machines
Smells like sewer when washing clothes
Washing machine mold / mildew odor is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned. After the washer has been cleaned your washing habits must change to eliminate what is causing the smell. Go to www.smellywasher.com and fill out the "washing machine help" questionaire to get sent advice on what to change to remove the odor and to keep it away.
Oct 05, 2009 | GE WSXH208A Front Load Washer
Funky smell from working Whirlpool Ultimate Care II
run the washer then smell the motor or see if anything has jumped the tub and causing the clutch to pull harder
Mar 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Burning smell
There are a lot of reasons could cause it. Best thing will be to open machine's service panel and to find out from where does this smell comes. Let us know with your results and we will see how could we help you.
Aug 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher and Paykel Aquasmart wl80t65c Logo
118 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
