Nothing
Hi -
If your water heater is working (ie: making hot water) then most likely your heater isn't leaking. Rather, the leak is coming from the cold water supply and running down the tank where you see it at the bottom of the tank. A working tank that is leaking would produce a leak of hot water - not cold. You should carefully check the cold water piping for a leak, drip or stream of water and make the required repairs.
A leak may not be your first problem in that situation, but it's still frustrating. I do agree with Steve though, that you should be checking for a cold water leak to see if that's where you should be focusing your efforts. If it's not something that you're able to easily fix, then hiring professional sounds like your best bet. http://www.frankniesencompany.com/water-heaters
If water heater is rusted out and leaking, then it must be replaced.
Following link has troubleshoot walk-thru
http://waterheatertimer.org/Leaking-water-heater.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Look at the top of the water heater. Is it wet? if so look higher, a lot of times the pipes leak at the shut-off valve. on copper, look for green-that is where the leak will be.
You can also wrap your hand around the cold water inlet pipe and see if water is running down it.
Yes, steve is right. leakage is not present in hot water heater because if water heater is leakage then hot water leak not cold water. if you unable to repair cold water leakage then hire any heating service provider company like Heating NJ Repair Service Licensed Insured Heating Contractors
