What connection do I use to connect a sony blue ray disc to on a Yamaha htr 6030 reciever to play music cd's
Set the input on reciever to cd,connected blue ray CD player digital out cable to the red terminal on reciever cd out in the audio box. Hit play on sony remote, but no sound!
Re: What connection do I use to connect a sony blue ray...
You said "...on reciever cd out in the audio box..." but it should the reciever IN that you connect to. Also is the BlueRay player capable of playing CD's ? When you press play on the sony remote, do the seconds start counting on the screen ? (ie: is it playing, but no sound is coming out?)
Hello The input selection done with the amp is not correct. It is now confugured to receive radio. just select input to AUX. Just pre 'amp' and then press 'input' repeteadly to select 'aux'.
hi, Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable. OK
Once you have installed all the cables to the system, you will need to go in to the Yamaha's system settings (see owner's manual) and assign the audio inputs accordingly. The DVD input will need to be set to the optical input # you have selected. Optical and digital coax are not preset in most cases. Once you get to the input selection assign the digital # for DVD and then exit out. You should begin to hear the audio immediately. If not you missed a step. I do this for a living and every unit has its own routine you need to learn.
Enjoy the system
Rob
The indicator is telling you you have a 2-channel input. You may have the Blu-Ray connected wrong. Or the source is only Stereo. I need more details to assess that.
The sound coming from all speakers is normal if you have any surround mode selected, regardless of the characteristics of the source
I imagine if you experiment you might find all speakers playing for any number of 2-channel sources, not just Blu-Ray. Besides actual Pro Logic decoding, the various surround modes can provide some interesting effects on non Dolby Surround material.
I recommend that you try them all on various recordings and you may find one or another of them preferable over vanilla stereo. I find that any given artist or music type, even within a given CD, may sound 'better' with different surround settings.
Do you have a normal (Playback only) CD player on the MD/CD-R input? It's supposed to support a RECORDING device as you can see by the OUT (REC) connections. A recorder would have shielded cables there and maybe the circuitry is such that ungrounded/unshielded output to the recorder allows a leak of the FM, which is developed inside the receiver.
Since you know that FM is leaking why don't you just selct some other idle source before selecting MD/CD-R? Have you also heard, say, the DVD, if it is playing when you select MD/CD-R?
Or skip the analog route entirelzy and run digital cables from your CD player to one of the Digital Inputs, if you have a spare one. They're all functionally the same. I guarantee the FM won't get in that way.
The Yamaha HTR-6030 offers two types of video monitor output: Component and Composite. You may need to connect both types to your television as the HTR-6030 does not have composite to component video conversion. In other words, to view your VCR on your TV, you need to use the composite video monitor connection. However, for a DVD player or other source that has component video connections, use the component video monitor output to your TV. If your TV has both types, you simply switch between the two with your TV remote to access the proper video monitor output signal from the HTR-6030.
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
