Cell Phones Logo
s
steve cross Posted on Dec 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung Galaxy 111 mini 1819on mobile phone, shows full signal but still cant make calls or text?
Turning off, changed Sim .
Ray
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Dec 02, 2014
Ray
Expert
Level 2:
Sergeant:
Answers
324
Questions
Helped
68546
Points
727
What error do you get when you try to call ? Are you sure the phone is not locked to another company ?
I picked up a Samsung GALAXY S 111 it's a T mobile phone but I have a Metro account this phone didn't have a sim card can I get a Metro sim for it will it work as a Metro pcs phone
Get a Free SIM Card. Then, Use Your Old Phone with Us.
https://www.consumercellular.com/.../get-a-free-sim-c...
Consumer CellularApr 29, 2015 - Here at Consumer Cellular, it's our mission to save you money ... I havea Samsung Galaxy S III phone, from Verizon and I'm wondering the same thing ... You can pick up a SIM card from our display at your local Target or Sears store, ... Dotmobile phones work with your company i need a sims card but not ...
Amazon.com: Samsung Galaxy S III S3 SGH-T999 T-Mobile ...
www.amazon.com/Samsung...T-Mobile...Smartphone/...
Amazon.com, Inc.
Rating: 3.6 - ‎185 reviews
Samsung Galaxy S III S3 SGH-T999 T-Mobile 4G LTE 16GB GSM WiFi. Sorry, this ..... The phone has never switched to the LTE tower or picked up 3G, 4G or LTE signals.Read more ... It is a more expensive phone but you get what you pay for. .... Igot the phone about a month or two ago and its already not working properly.
Mobile phone is a samsung galaxy s 111 mini just wanted to know if there are any light to indicate a message or charging
Yes .. Samsung ain't have a tiny light on top showing its charging however on screen it shows if its charging and for text messages thr is envelope kind symbol when a message is pending for reading in case someone closes pop up message that shows 'You got some unread messages'
1helpful
I have no signal on samsung s2
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
4helpful
My samsung Duos gt-b5722 not showing any network. when i insert sim it shows full signal but when i dial a number it shows emergency call only. i cant send any message. when i call on my no. it says its...
Try other sim cards in the phone to be sure the problem is not from the sim. When you are sure the problem is not from the sim, try to reset the phones's factory settings. If it still does not work, then flash the phone.
If the fault was detected to be a sim fault, then get another line of the same network, and call your mobile service operators.
Hope this was helpful?
2helpful
I forgot my phone lock code for a samsung s7220
For all:
*#06# Show IMEI
*#9999# Show mobile Software Version
*#0837# Show mobile Software Version (instructions)
*#0001# Show Serial Parameters
*#9125# Activates the smiley when charging
*#0523# LCD Contrast
samsung-mobiles2.jpg *#9998*228# Battery status (capacity, voltage, temperature)
*#9998*246# Program status
*#9998*289# Change Alarm Buzzer Frequency
*#9998*324# Debug Screens
*#9998*364# Watchdog
*#9998*377# EEPROM Error Stack - Use side keys to select values
*#9998*427# Trace Watchdog
*#9998*523# Change LCD contrast
*#9998*544# Jig detect
*#9998*636# Memory status
*#9998*746# SIM File Size
*#9998*778# SIM Service Table
*#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error
*#9998*786# Run, Last UP, Last DOWN
*#9998*837# Mobile Software Version
*#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated
*#9998*862# Vocoder Reg - Normal, Earphone or Carkit
*#9998*872# Diag
*#9998*947# Reset On Fatal Error
*#9998*999# Last/Chk
*#9998*9266# Yann debug screen (Debug Screens?)
*#9998*9999# Software version
*0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1)
*0002*?# unknown Samsung's comand
*0003*?# unknown Samsung's comand
For Mobile phones SGH (R210, T100, A300...)
if Samsung code is in format *#9998*xxx#
try write in this *#0xxx#
SGH-600
SGH-2100
*2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0
*2767*2878# Custom EEPROM Reset
Samsung mobile phone codes: Samsung E700
*2767*688# remove USER CODE and SIMLOCK
Samsung mobile phone codes: Samsung V200
Unlocking:
Power on the mobile phone without SIM card and type these codes:
*2767*63342# and press green button
*2767*3855# and press green button
*2767*2878# and press green button
*2767*927# and press green button
*2767*7822573738# press button
Phone will be unlocked, but all trims are reseted !!!
Mobile phone must be fully charged
Samsung mobile phone codes: Samsung S500
Unlocking
*2767*MVT# (*2767*688#) E2P MVT Reset
*#SIMLOCK# (*#7465625#)
1helpful
I need to unlock the network lock for samsung sgh l810i
hi try these codes
*#06# Show IMEI *#9999# Show mobile Software Version *#0837# Show mobile Software Version (instructions) *#0001# Show Serial Parameters *#9125# Activates the smiley when charging *#0523# LCD Contrast
*#9998*228# Battery status (capacity, voltage, temperature) *#9998*246# Program status *#9998*289# Change Alarm Buzzer Frequency *#9998*324# Debug Screens *#9998*364# Watchdog *#9998*377# EEPROM Error Stack - Use side keys to select values *#9998*427# Trace Watchdog *#9998*523# Change LCD contrast *#9998*544# Jig detect *#9998*636# Memory status *#9998*746# SIM File Size *#9998*778# SIM Service Table *#9998*785# RTK (Run Time Kernel) errors - if ok then phn is reset, info is put in memory error *#9998*786# Run, Last UP, Last DOWN *#9998*837# Mobile Software Version *#9998*842# Test ******** - Flash the screenlight during 10 sec and vibration activated *#9998*862# Vocoder Reg - Normal, Earphone or Carkit *#9998*872# Diag *#9998*947# Reset On Fatal Error *#9998*999# Last/Chk *#9998*9266# Yann debug screen (Debug Screens?) *#9998*9999# Software version *0001*s*f*t# Changes serial parameters (s=?, f=0.1, t=0.1) *0002*?# unknown Samsung's comand *0003*?# unknown Samsung's comand For Mobile phones SGH (R210, T100, A300...) if Samsung code is in format *#9998*xxx# try write in this *#0xxx# SGH-600 SGH-2100 *2767*3855# Full EEPROM Reset (THIS CODE REMMOVES SP-LOCK! but also changes IMEI to 447967-89-400044-0 *2767*2878# Custom EEPROM Reset Samsung mobile phone codes: Samsung E700 *2767*688# remove USER CODE and SIMLOCK Samsung mobile phone codes: Samsung V200 Unlocking: Power on the mobile phone without SIM card and type these codes: *2767*63342# and press green button *2767*3855# and press green button *2767*2878# and press green button *2767*927# and press green button *2767*7822573738# press button Phone will be unlocked, but all trims are reseted !!! Mobile phone must be fully charged Samsung mobile phone codes: Samsung S500 Unlocking *2767*MVT# (*2767*688#) E2P MVT Reset *#SIMLOCK# (*#7465625#)
2answers
I've forgotten the pin code to unlock my Samsung gt S5230. Is there a way of unlocking it please?
hi try these codes
1helpful
I had forgotten my samsung metro 3310 app codes
hi try these codes
May 11, 2010 • Cell Phones
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
