Radio Communications Logo
w
walter toy Posted on Dec 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Youyube.com/pair how to enter code - Radio Communications
Jeff richtman
Level 2:
Sergeant:
  • Expert 324 Answers
  • Posted on Dec 02, 2014
Jeff richtman
Expert
Level 2:
Sergeant:
Answers
324
Questions
0
Helped
62842
Points
909
Please make sure the address you are trying to goto is correct.
It should be https://www.youtube.com/pair
Instructions are listed on the page in the link above.
However you posted this question in Headsets, If this is a bluetooth headset you are trying to pair with another device, you will need to first make sure the device you are wanting to pair the headset with is bluetooth capable.
When using blue tooth and paring the keyboard to the tablet it ask to enter the 8 digit code on the screen and press enter on the key board.
There should be a confirmation code to whatever device you're pairing it too.
for example, if I was pairing mine to "laptop", I would see this http://cdn.makeuseof.com/wp-content/uploads/2012/09/bluetooth-pairing-passkey-on-android.png?20efae
and then type that code in.
1helpful
Youtube com pair enter code
you get the code on a compatible device. for example, pairing on your youtube app on your cell phone will give you a code to put in. usually devices pair by themselves though.
Youtube com pair enter code 674 889 190
That's the code you enter into one of the YouTube apps to pair the app with your TV or vice-versa.
I dont know where to find pairing code
If you are connecting to Bluetooth headset, check the manual of Headset to find default pairing code.
If you are connecting to other mobile phone or laptop, you have to enter any pairing code you want and then enter the same pairing code to other mobile or laptop and both devices will be paired.
May 25, 2011 • Cell Phones
1helpful
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 • Cell Phones
2answers
N97 paring code
It is a passkey to allow further communication between both devices. It is normally entered just once. Already paired devices communicate with each other, provided that their bluetooth stacks are turned on. You can enter any number you want as pairing code, provided that it is the same one on both your phone and your computer. By the way, the most commonly used code for bluetooth pairing is '0000' (four zeros).
Hope it is the kind of information you were looking for.
Cheers! Carlos
2helpful
When I try to pair my Nokia N97 mini to my 3200 LS parrot it wont pair. My phone sees the parrot but then then says pairing failed and does not give me the opportunity to enter the pin code. Any thoughts?
firstly you need to go to settings / paired devices & delete any old pairings, the go to settings / pair with phone and it will give you a code to enter. Now search for bluetooth devices on your phone and enter the code when prompted.
Good luck.
It doesn't let me punch in the code of 0000. other phones are easier to pair.
Go to settings/ pair with phone/ other phones. it will then give you the code to use, then search for new paired device from your phone, when it finds parrot, click pair and enter code shown on parrot screen. Make sure you delete all other paired devices from parrot first. instructions can be found at parrot.com
6helpful
2answers
Pairing code?
With the headset off, press and hold the multifunction key until continuously lit. Search for the headset with your phone. Select the headset, and enter passcode 0000. If the pairing is successful, the indicator light on the headset will start to flash slowly.
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
