Question about Nor-Lake Freezers
Freezer is beeping and displays flashing CL,...WHAT IS THE PROBLEM?
First the freezer alarm beeping with red light flashing, inside light went out and freezer standard electronic temperature control display unit no longer lights up.
Hi Loretta, I am happy to assist you!
Based on the symptoms you are describing, it sounds like your freezer may possibly have a communication problem with the control board, a potential wiring failure, or faulty temperature control. Before reaching out to a professional, let's try resetting your freezer. This can be done by either unplugging it or flipping off the circuit breaker. It is important to wait approximately ten minutes. If it proves ineffective, In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the exact diagnosis of the appliance.
Best regards!
Jan 31, 2014 | Frigidaire Freezers
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
Jul 24, 2011 | Thermador T18BF70FSE Freezer
Beeping coming from freezer
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 18, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
After power cut the temperature of the fridge and the freezer termperature are just flashing and making a beeping noise
It means the compartment temperatures are increased then allowed limit.Generally in some appliances the maximum temperature is indicated at the display with an alarm after the electric cutoff.If the temp is high in the compartments
Jun 29, 2009 | Whirlpool Freezers
Freezer temp display beeping and going through different temps rapidly!
Seems that you may have a faulty temp control switch or it is stuck in position. Check this also make sure that the air vents are clear.
Thanks J
Feb 16, 2008 | Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Freezers Logo
1,383 people viewed this question
Top Nor-Lake Freezers Experts
Dennis Boxerman
Steve Allison
Steve Allison
Are you a Nor-Lake Freezer Expert? Answer questions, earn points and help others
