Tried to charge it but it wont charge tried to look for information but wont find eny information
I assume you mean a JBL Charge. As for that specific model I am unfamiliar, however if when you try to charge electronics they will only flash a red light that's usually a battery or charger error signal. Most likely either a battery in the battery pack has gone bad, a contact has come loose or your charger has broken. Did you happen to drop it shortly before this error occurred? Also was the battery completely dead right before this happened? Sometimes I have noticed wireless devices will refuse to charge a battery if it is completely drained.
SOURCE: JBL PB10 subwoofer sounds distorted and lights on the front flash
More likely to be the Class D power amp module, but you should look through the service manual to make sure all the parts are installed correctly. My PB10 AMP module went out and you cannot get one anymore.
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
