It also has a small hole that indicates DC connection? Has 3 lights that don't work. Its 5 years old, but has never been used, I don't think its ever been opened, and I don't recall ever seeing a combination. I assume combo inside?
SOURCE: Safe SENTRY S3877 can not open the door
here is the number for customer service, 800-828-1438
SOURCE: unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
SOURCE: no override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
