Question about Kidkraft Best Quality Outdoor Storage Bench w/naby stripe cushion
My sons Nabi won't charge and I don't know if it's the charger or the Nabi's battery help me
  • 31 Answers
Contact Nabi. I have had several issues with nabi. Most likely the slot where the plug is placed is disconnected inside somehow. You can try placing the charger in the freezer for about an hour. There is a thermal fuse that over heated that will reset it. Nabi sent me a new tablet twice. They have great customer service.
Posted on Dec 01, 2014
SOURCE:
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
Every time I try to charge the nabi xd the screen still stays black and it won't power up??
First check the charger is working. If you are using a usb cable use a short fat one (less resistance, so more power/amps).
Some times this is a batrery lockout. If you can figure out how to open the unit and unplug/replug the battery that could fix it.... Look to youtube for opening and pulling batrery.
Dec 30, 2014 | Nabi XD
Nabi Tablet will not turn on, how can I fix it?
You should first verify that it is getting power. There have been some issues with the nabi's charger that you can read about here. While plugged in and charging, the red light should be on, and will change to green when it has finished charging.You should then be able to turn it on. You can download the nabi manual here.
If the battery is fully charged, then the next thing to try would be to remove the battery and let it sit for several minutes. However the nabi wasn't designed for a consumer to do this, so you should email nabicares@nabitablet.com, or call 1-855-275-6224.
Oct 21, 2012 | Computers & Internet
Red and green flashing lights on 18v lxt charger
Batteries don't always look degraded but if they've been in use for a while or have a bad cell, they will show up bad on the charger and it won't charge them. The only way to test the batteries is to try to charge them on another charger. If the batteries show defective on another charger, they are bad and you'll have to replace them. Also try to charge some batteries you know to be good on your charger to see if it's the problem. If your batteries charge on another charger, your current charger is bad and they don't have any replaceable parts in them so you'd be looking at replacing it.
Feb 21, 2012 | Makita Tools & Hardware - Others
My 2000 licolin battery died the key won't open the door lock how do get in to the engin to put jumpers on the battery to give it enough power to work the locks ps i don't understand why the key...
The key has to open the drivers door
Raise the car up,support it,& put your battery
charger on the starter battery cable terminal
& ground the black clip
Try charging the battery for 4 hours or so
Jul 02, 2011 | 1998 Lincoln Continental
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Kidkraft Best Quality Outdoor Storage Bench w/naby stripe cushion Logo
712 people viewed this question
Top Kidkraft Furniture Experts
Tom Chichester
Marvin
Marvin
Are you a Kidkraft Furniture Expert? Answer questions, earn points and help others
