Cleaning the main suction pipe, cleaning the filter into the mulch bag, over revving in case something stuck.
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
You'll have to go into the turbine assembly and check the bearings. Mine stopped spinning and this solved that problem. I simply began working the seized bearing until it rolled again, packed it in grease and reassembled.
SOURCE: bissel proheat 2x main suction problems
bissel pro heat x2 does not suction up the cleaning fluid
