Omega Paslode 901000 Impulse Cordless Finish Nailer Logo
A
Ady king Posted on Dec 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Paslode pin gun.. Battery fullycharged but no power and indicates on gun glows red. Any answers.
Differentl batteries . All batteries I tried work well in my other 1st fix gun
Alex Leigh
Level 2:
Scholar:
New Friend:
  • Expert 70 Answers
  • Posted on Dec 01, 2014
Alex Leigh
Expert
Level 2:
Scholar:
New Friend:
Answers
70
Questions
Helped
49067
Points
149
Hi Ady,
Judging by all the different batteries work in other tools, my guess is that the circuit board has failed. If you feel up to it, you just need to solder a new one in. If not you need to weigh up the cost of having done and the cost of a new tool?
Regards
Alex
2 Related Answers
Anonymous
  • 67 Answers
  • Posted on Sep 13, 2010
SOURCE: Paslode finishing nail gun won't fire? Battery is
Give it a thorough cleaning.. if it still does not fire you might have to replace the spark plug.
Anonymous
  • 43501 Answers
  • Posted on Mar 06, 2011
SOURCE: Paslode impulse finishing gun wont
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
There is no light coming on with a battery connected
First what kind of gun? If Paslode- may need new gas cartridge. And is power light green (still paslode gun.) If other type of gun can't help. sorry.
1helpful
2answers
Paslode framing nailer: compressor powered, hisses but will not shoot nails, appears to be in the sliding mechanizism that touches the wood first before it will shoot, help
I've used paslode for years and whenever there was a "hiss" of air and no fire- it was o-rings- When were the o-rings changed last? And how do you know they are in 'good shape'? You can't tell by just looking at them. If that isn't the problem then I can't help. Just as an aside- do you oil the gun (down the air intake nipple) every time you use it? Lack of oil will wear out o-rings fast. Sorry if this isn't overly helpfull but most gun problems are o-ring or seal related unless you've worn out or damaged a mechanical part.
Gun will not work, battery charged as soon as you put it in the gun it goes red.
hi it could be your gun if it is flashing red&green this means theres a fault with the gun if it is just red try cleaning the battery treminals with a bit of sand paper some times they get a bit dirty and dont get enough contact with the gun hope this helps
1helpful
My paslode battery is fully charged but flashes red and does not fire gun.any ideas?
Paslode troubleshooting indicates that the battery contacts might be corroded, try cleaning them first and also look at the contacts inside the tool for same condition, they also say it might be a bad battery. Do you have another one that you can try? Let me know if you need more help before voting please. Thanks
Gun will not fire, battery is charged & good ??? model #IM25011 part # 900400 Bob
problem solved - battery charger indicated that battery was charged with green light on, took battery ouit & placed it back in charger & red light came on after doing this three times the battery was fully charged and the gun worked fine.
thanksBob
Fan not working
If the battery is flashing red, the battery is not charged or on a minimal charge.
Have you attempted to recharge it and does it still give you this symptom?
K
Paslode works intermittently
I had a similar problem with my impulse framer. The solution was to adjust the battery contacts within the gun. The contacts were not making good connection with the battery. I also adjusted the safety foot out to max so that the trigger mech. could function more reliably. Other problems I have had with this gun were related to the proper seating of the fuel cylinder and condition of the battery. My battery would no longer hold a proper charge causing the red light error.
Top Omega Tools & Hardware - Others Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Larry Ng
Larry Ng
Are you an Omega Tool and Hardware - Other Expert? Answer questions, earn points and help others
