Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
Anonymous Posted on Jul 06, 2009
Can't disengage oven door lock
Self-clean was started while door was open. Now lock is engaged but door is open and the self-clean won't cycle through. There is no way that I can see to cancel the self-clean. I'm getting error code F5. I need to know how to cancel, or how to disengage the lock. Thanks.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
545
Points
Lock disengaged on its own after a day. Oven is now clean, everything working properly.
Brandt FP464 Oven Door Locked
On most of these ovens, you can either unplug the unit or flip the breaker from the main and keep it off for ten minutes, then either plugs it back in or turn it back on, and then hit and hold the start/cancel button on the control board for twenty seconds. Yu should hear a beep and then you should see the display light up and ask for you to set the time. If it does this, then the reset has worked. If so, put the oven into a self clean cycle and hit start, listen for the machine to come on, and about a minute later cancel the cycle and see if the door unlocks. If that doesn't work, you may have a bad door lock assembly and you will be forced to manually unlock the door.
To manually unlock the door, stick a screwdriver or heavy wire coat hanger in between the door oven and the door lock and see if you can disengage the door lock. If you manage to get the door open, leave the door open and put the oven into another self clean cycle. If after hitting the start button to activate the self clean cycle, you notice the door lock either not moving or getting stuck closed again you will need a new door lock assembly. If after hitting the start button, the door lock seems to be working fine, the door lock had probably shorted out during the cleaning cycle and looks to be okay now.
Aug 06, 2023 • Ovens
I can't get my GE range to self clean, I keep getting a F91 error whenever I try to clean.
Unfortunately, the F91 error indicates that the door lock is not functioning or the signal that the door is locked didn't get to the control unit. The range will not begin the self-clean cycle if there is a chance that you could open the oven door when the oven is dangerously hot.
First try cycling the power by unplugging the range (or turning off the circuit breaker). Next check if the lock has engaged. If the lock doesn't engage, check if the mechanism is bent or binding. Next check the wiring to see there is damage that will prevent the communication between the control board or the door lock. Check for corrosion at the wiring harness connections.
If the error happened after doing a self-clean, I'd suspect the door lock hadn't released. That can be related to a damaged over-temperature sensor or the lock itself. If the range has been self-cleaned before, it's possible that the lock was broken after forcing the door to open after that self-clean cycle.
You may need to replace the lock, the wiring or the control board. Please add a comment with the model of your range for a parts diagram. If your range is under warranty, contact GE.
I hope this helps.
Jun 26, 2018 • GE Ovens
How do I turn off?
Just open the oven door and you'll see a button that the door actually pushes against... with your finger hold the button in and turn the oven on to the self clean cycle... While still holding the button wait a few seconds and then turn the self cleaning cycle off, this should disengage the door latch... Always keep the button engaged until the self clean cycle is off...
Mar 25, 2013 • Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 • Ovens
2helpful
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 • Ovens
3helpful
2answers
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
7helpful
2answers
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 • Ovens
Top Kenmore Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
