Question about Hisense TA42P40M 42 in. Plasma Television
The power went and return and my hisense tv didnt power up i change the main board with a new one the same ting happen . What is the problem
  • 54 Answers
Could be your power supply or your bulb set if its backlit.
Posted on Nov 30, 2014
SOURCE:
I have a hisense 55 inch tv and the sound went off after 1 hr The model number is HL55K310PZL3D
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.//
Feb 05, 2018 | Hisense Televison & Video
I have a hisense 55 inch smart tv while watching it i heard a pop sound then tv went off what could of it been whats wrong wi5h it wont turn on
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 11, 2017 | Hisense Televison & Video
Hisense tv went black screen I can still here sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 05, 2017 | Hisense Televison & Video
Hisense TV: Dim pic. 2 wks later the pic just went out. Still had sound and could only see the pic when lights were off. Now the TV won't turn on. No sound. No back lights.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Oct 12, 2016 | Hisense Televison & Video
Lcd Hisense TV powers up with blue light,but no picture and sound.
Main board is probably bad or the power board is not powering the main board. Common problem with Hisense tvs and their customer service is lacking if under warranty. My hisense chromebook has been dead for almost 2 months...still waiting on a return authorization for warranty repair.
Jul 03, 2016 | Hisense Televison & Video
My TV has power on the main board but won't turn on. When I plug it in the speaker pops but then nothing happens after that. Nothing looks bad on it. It's a 50" hisense model # 50K23DG
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 29, 2015 | Hisense Televison & Video
What makes the HISENSE LCD (Model LCD 42W58P1) power supply failed to produce output voltage goes to the main pc board?
First of all the power supply makes 'Stand By 5 or 3.5V which goes to main board. When we give power on command to the TV the main board sends 'stand by or Power ON' command to the power board which then makes other necessary voltage for the main board as well as other sections. If the power board does not receive 'Power On' command from main board, it will not produce the necessary voltages to operate the TV set.
May 20, 2015 | Hisense Televison & Video
I change the main board on my hisense tv 46" and it dont power up what must i do
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 30, 2014 | Hisense TA42P40M 42 in. Plasma Television
My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Mar 20, 2013 | Hisense Televison & Video
The color on my tv has gone crazy. There's either a blue tinge or a yellow tinge when I adjust the colour (so either people look like they are faintly related to a smurf or have scurvy!!). I am also...
I would suggest to unplug the TV from the AC power outlet first, wait a couple of minutes to plug it back in. If that does not work, the main board is defective since is not providing proper video info to the main digital controller board (D board). The Main board part number is: TNPH0721AJS or TNPH0721ADS. If you need to verify the main board part number, you will need to remove the back cover of your plasma to check it out.
Let me know if you require further assistance.
Nov 27, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Hisense TA42P40M 42 in. Plasma Television Logo
82 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Paul
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
