Music Logo
J
John Posted on Nov 29, 2014
I have a Technics PR-305 Digital Piano the speaker and the amplifier blew. I noticed that my speakers burned. Can that be repaired to work again?
I went to turn on the Technics PR-305 Digital Piano, the Technics PR-305 made a loud humming noise then quieted down. I turned the volume button all the way up but got no sound I tried the headphones but got no sound either, Can that be repaired to make it work again?
greno1
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Nov 30, 2014
greno1
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
1929
Points
31
Yes, can be repaired. Sounds like sound output power chip has gone bad.
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 • Music
I have I Technics PR-305 Digital Piano. I took it apart to try to clean the rubber contacts with rubbing alcohol. It improve some what, then later on I turned on my Technics R-305 Digital Piano.
I would suggest taking it into the nearest factory authorized repair center. Go to the Technics web site to find one in your area.
Dec 10, 2015 • Music
2helpful
I have a Technics PR-305 Digital Piano It was working at the End of October, but around the beginning of November 5 my Technics PR-305 Digital Piano made a loud humming sound, then it quieted down, I
Also, in addition to more info I need; look on p 91 of the online owner's manual linked below. Pay attention to Sounds and Effects, the first section therein. Follow the directions closely, esp., read pp. 26, 83, and 86 which are referenced for detailed help w/ sound issues. TECHNICS SX PR305 Manual Page 91
Nov 26, 2014 • Casio Music
I have a Technics PR-305 Digital Piano. I was playing a couple of songs on it., then about 5 days later. around the beginning of November I went to turn it on it made a loud humming sound from the sp
Yes it can.....but you will need the schematics and some test gear in order to do it.....and a soldering iron....what do you mean by no surround on the speaker?? Can you post a pic??
Nov 25, 2014 • Music
1helpful
I have A Technics PR-305 Digital Piano I have a Distortion in my speakers I was told that it would be wise to replace the speakers Where would I go to replace the speakers?
That depends on where you live and if you want to replace them yourself. If you do then you need to make sure they match what you have, (impedance, wattage etc)
Feb 01, 2014 • Music
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 • Music
2helpful
I have a Technics PR-305 Digital Piano That has a Distortion in My Speakers it`s not really bad, Would I have to get new speakers, if so where would I get them at? or could they be repaired?
It sounds like the rubber around the speakers has perished. Open the cabinet to check. If so, measure the size and order replacements easily on internet. It's a simple job for someone with a little knowhow
1helpful
It sounds like you are in need of a new piano. These are common issues with keyboards. The age is a big factor. It would cost just as much in repairs as it would to buy a new keyboard.
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
