Seagate Barracuda 7200.12 1 TB 7200rpm SATA 6Gb/s with NCQ 32MB Ca Logo
J
James Sale Posted on Nov 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I read a barracuda 7200.12 1 TB drive? I need to get data off of it, not boot on it
I have a box that I can put drives in to read them but the 7200.12 has completely different connections. This drive will no longer boot up and I need to get data off of it.
Mike
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Seagate Master 884 Answers
  • Posted on Nov 29, 2014
 Mike
Seagate Master
Level 3:
Renaissance:
Answers
884
Questions
Helped
194909
Points
4435
Hi
The easiest way that I have found is to get a kit that allows you to power the drive from a separate wall socket and connect a data cable from the drive to a USB socket on the computer. Such a kit usually consists of four components:
A mains lead - wall socket to black box transformer
The black box transformer - has outlet 4 pin molar for IDE drives
A USB cable ending in unit for connecting to an IDE drive or SATA cable
A SATA cable for connecting to the SATA drive (your Barracuda 1Tb in this case)
The components can be seen on this Ebay site:-
USB 2 0 TO SATA IDE Cable for HDD with Power Converter Adapter UK
The one thing missing from this set up is a power conversion cable converting the molar 4 pin power connector to a SATA power connector. These can be a molar plug to go into the lead from the black box and either a single SATA power plug, or a double SATA power connector as shown here :
Molex to 2x SATA Power Dual Power Adaptor Splitter Cable Lead Hdd Cd DVD...
This option is inexpensive and offers great flexibility in the type of drives that can be connected to a USB port, 2.5 or 3.5 inch, SATA or IDE.
In your particular case you may be able to get a dock that connects to a power supply and a USB port, with an opening in the top to take a SATA drive. These tend to be more expensive and only suitable for SATA drives not IDE.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Alli Abiola
Level 2:
Champion:
  • Expert 256 Answers
Alli Abiola
Expert
Level 2:
Champion:
Answers
256
Questions
0
Helped
29760
Points
438
Good day James,
I will advice you contact an engineer who has a better knowledge so that you wont tamper with the drive.
Thanks... Alli
How do I read a barracuda 7200.12 1 TB drive? I ne - 25300762-sq4cj5xbxru4sqfkaulld1b3-5-0.jpg
5 Related Answers
Anonymous
  • Posted on Jun 19, 2009
SOURCE: External Hard Drive I/O Error
Somehow i tried to format and it was formatted. took pretty long time as 1 terabyte. i thought all is ok as the drive was accessible. Just to double check, i scanned the drive thorugh the seagate manager and it got stuck on 10% for few seconds and then said that the hard disk is faulty and should be immediately returned if under warranty. and to confirm it also gave me read errors http://www.dtidata.com/resourcecenter/2007/05/15/how-to-tell-hard-drive-physical-damage/
so i'm giving it to seagate service centre as it probably has physical faults, bad sectors. and someone told me that 1TB hard drives are not stable.
binesheb
Binesh Ellupurayil Balachandran
  • 155 Answers
  • Posted on Jul 04, 2009
SOURCE: How to extact the data off the Seagate Barracuda 7200.10 320GB HD
if its your motherboard that crashed then ther is no problem with your hard disk. connect your hard disk to any other computer and you can access all the files in it.
if it is your harddsik that crashed then try recovery utilities like western digital data storege manger or any other disk recovery tool available for free. if still it fails then you can recover your data if you hand over your hard disk to the nearest service centre. but recover from a hard disk only if its very valuable. thay will charge you per MB of data recovered
Anonymous
  • 121 Answers
  • Posted on Jul 06, 2009
SOURCE: Barracuda 7200.10 (how to make it slave)
If I remember correctly then you nee to REMOVE the jumper to have it as a slave drive. Otherwise the second from left (with power plug on the right) is usually the SLAVE position on those drives
Anonymous
  • 6 Answers
  • Posted on Sep 14, 2009
SOURCE: hard drive failure segate barracuda 7200.9
how about scanning and trying to repair the sectors with hirens boot cd. There is a utility on it called hd regenerator or something like that http://www.hiren.info/pages/bootcd. I think you have to download this cd from piratebay first. There is no download from his website.
Anonymous
  • 466 Answers
  • Posted on Nov 25, 2009
SOURCE: Seagate Barracuda 7200.9 SATA driver problem
If the laptop is also XP, the drive should be recognized without problems. Sometimes this may not happen if the disk is unusually partitioned (could happen if you manually dual-booted it with Linux, for example). Verify the enclosure is working properly and has enough power supplied to, and that it appears in Device Manager. If all this applies, the enclosure must be considered working and the problem might be in the partitioning or disk access.
In XP Pro, do Start > Run Command > DISKMGMT.MSC and press OK. See whether the disk appears (if it doesn't, it's the enclosure, or its drivers - or the disk was dying and is now dead, but that's not very likely), select the NTFS or FAT32 partition - ignore any others - right click and mount the unit as drive, say, G.
If it doesn't work but the partition is found, you may need a more powerful tool such as Paragon Partition Manager.
See also here:
http://support.microsoft.com/?scid=kb%3Ben-us%3B307889&x=12&y=12
Bios cannot read hard drive
Hi Robert,
IT could be that the Barracuda drive is formatted for boot up. I would boot up with the drive that boots, and make the Barracuda a spare drive, so you can go in and first see if has any issues as a drive,(meaning sector 0 errors, and if you can access it, then you can format it as a boot up drive, or get what data on that drive off for your friend.
Good Luck Mark
When computer boots up I get this error code A disk read error occured code 0F00:0666
A bad hard drive or the boot sector (the map of the hard drive contents) has an error.
You have two choices. If you run regular backups you can do a full restore including the boot sector, if not, you'd have to format the hard drive and lose your data. Then reinstall Windows and start from scratch.
The other option that loses your data, as well, is replacing the hard drive if it's defective.
My new Seagate Barracuda 7200 does not
Hi Simlei.
If its a modern, fairly new drive, it should have built-in firmware, without a need for extra drivers.
If you OS is old the OS itself may not be recognizing the drive's 'language', especially if the bus-width differs, ie 16/32/64bit.
As 1 TB is quite recent on SSD's, I guess its new.
My 1 TB Toshiba just plugs into USB and Win Explorer detects it as a storage drive.
Regards, Clive.
I am trying to install window xp2 in my system and having seagate 7200.10 barracuda 160 gb but setup works only upto 27% and a problem occer that disk may be damage or check that SCSI is terminated.
I've got bad news for you . Your hard drive is damaged for sure and you will need to replace it . It's totaly impossible to install a OS on a damaged drive and at least not recommended .
To retreive data , you will need to disconnect the drive and read it in a external box from a healthy computer .
The chance that the issue would be due to a defect SCSI connection is extremely small .
Regards .
1helpful
I have Seagate 200GB HDD "ST3200820AS ATA" I have very slow data transfer now a days.I use licensed antivirus scanned my all drves cleaned few spyware's now everything is clean but still slows.I have tried...
only a low level format can fix the issue...
save all data from this drive to a new drive,
use an application called KILLDISK
download from my shared drive...
the application that u will downlaod is a auto boot and dos utility...use any burning software to burn a CD using the "ISO-burner" in the downloaded file.....
u need to boot the PC using this disk in the CD drive, so change the boot seq in bios to CD as 1st boot drive
use a new empty CD to make this system disk, read the "Read me first file there" and then wipe ur disk clean with the DOS utility of KILLDISK
this will make ut disk as good as new...
1helpful
Lights on nobody home
Well if it is less than 2 or 3 years old you could contact them to attempt a sawp out of the drive. Over that - replace the unit. IF you do - you might want to consider a duel disk enclosure so if a drive dies, your data does not. you can build one yourself (1 TB duel drives, Raid 1) for a total of 252 bucks, with good drives (Seagate - Barracuda) Yes I swear by the Seagate Drive. For off teh shelf they have worked very well in every application I have deployed them.
I've been burned by too many single drive failures - even when I have the data backed up it is still a royal pain.
2answers
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
2helpful
2answers
Dell Vostro 200 desktop with Windows XP is not able to handle two
Vista doesn't generally like to be installed on a hard drive that big. Well, Windows, in general doesn't.
And, from the sounds of it, you didn't install Windows on your new primary 1.5TB drive, you just copied it from the 500GB drive, which won't work.
Here's what you should to, to solve this:
1) Swap out your 1.5TB drive with the 500GB drive again.
2) Swap out your secondard 1.5TB drive, with the new one.
3) Create a partition of 120GB or less on that drive
4) Install Windows on the new partition.
5) Put the other 1.5TB drive back in, as secondary.
Once that's done, you can swap out the new 1.5TB drive with your Windows partition on it, in place of the 500GB drive.
When you boot, Windows may ask you to select which operating system you want, just select Windows Vista, and you should be good to go.
I had a similar issue a few years ago, when I tried to install Windows on a 1TB drive, and couldn't get it to work. Once I partitioned a smaller space, it worked like magic.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
