Hook up the RCA to your cable/satellite box. We tried direct to tv and doesn't work but worked instantly through our satellite box
You'll need some sort of audio cable to connect the TV's sound or audio output to the soundbar. For the most basic connection, use an RCA-style cable ( like the one found here: http://goo.gl/5F8yLh ) to connect your TV's audio output to the soundbar's input. Most soundbars also have an SPDIF input ( like the one found here: http://goo.gl/2F2rKs ) and most modern TV's have an SPDIF output. Get an SPDIF optical digital audio cable to connect the two devices together. Once you've decided which type of connection to use and have connected the TV's audio output the soundbar, then make sure you select the proper input on the soundbar. That should fix your problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/daren_80e8def41854e57e
SOURCE: ilive 37
Turn off the sleep mode. For some reasons the geniuses ship it with a sleep setting already on. Hold the sleep button til it shows the time then press the sleep button several times until it displays 00. good luck!
If you need further help, reach me via phone at https://www.6ya.com/expert/alicia_a8df133aa44867a7
SOURCE: how do i get a manuel for it202b soundbar
The manual can be downloaded from this site.
http://content.etilize.com/user-manual/1022923625.pdf
Follow instructions on top of page 7 using the Source button.
