Have you checked cooling fans
I have a 82inch dlp wd-82738 the bulb went bad put a new bulb in and broke the ballast cable can the cable be just replaced
I hate being the bearer of bad news, had the same problem, and I found out that the problem with DLP is that after so long, nothing that you do will fix it. A TV repairman offered me $100 for my set and I took it, that was 2 years ago and it still goes through bulbs and ballast several times a year. Now when i see him he always says I never should have taken that TV. It never plays long enough to sell it.
On a liter note: 4k si approaching $1000 now, that's the way to go.
SOURCE: yellowing spots on 52 inch LCD Mitsubishi display
have the store fix it you need a tech that has the right equipment to fix that. Since you say you replaced the lamp I assume you mean a LCD micro projector not an LCD Flat panel. There is a piece of equipment that a tech should have that can be plugged into the TVs circuit board and it can fix the spots with an electric pulse. I have seen in done on micro projectors in the store that i work by our techs. So my advise is have the store fix it before your warranty runs out.
SOURCE: changed lamp on my mitsubishi 73733 tv wont come
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?) Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself it will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate it accordingly. Good luck.
SOURCE: my 60" dlp mitsubishi tv
Sound /No picture- Have you replaced the Lamp?
If Not, First make sure fans are running when Tv is Turned on .Then if fans are OK ,Most common reason is the Lamp.
What is the Model # that is printed on back of TV?
