Y220 - U00
It looks like the Huawei launcher is failing to load. The launcher is basically Huawei's personal skin for your launcher. As to why it's crashing, I'm curious if you've flashed it with a custom rom or anything. Otherwise, the best thing to do is to go into settings, and reset the phone to manufacturers default.
This will erase everything on your phone, so make sure to back-up any files you want to keep, like pictures or recordings.
SOURCE: pattern unlock code
if you fail it too many times (think it is 5x), it should offer you to reset it with your google account or using backup pin code, if it is your device, you surely know one of theese.
SOURCE: How to setup internet on a Huawei y220
Do check the manual settings.Internet connection can be done through Wifi or mobile data.If you are trying through Wifi..switch ON the Wifi in your phone and it will automatically detect the nearby WiFi devices..select the one that you want and provide the necessary password authentication if required..you will be directly connected to the internet.
If you choose mobile data...try to get a 3G or 4G speed sim since it is faster..and do the respective settings if any, by contacting your network provider.You will be connected to the internet.
You can get the upload and download speeds using
ScanmySpeed.com
