SOURCE: clock and oven inoperative on elan rangemaster 90
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
SOURCE: Only half the grill is working
There are two elements on the grill, left and right. One has failed and needs replacing. Can't tell you how, we haven't got that far, but we bought replacements from e-Bay £9.99 each + £2.50 P+P. Official suppliers charge £21+.
Beth
SOURCE: rangemaster classic 90
Regardless of the clock running, if the timer is not set to zero and off, the oven will not function. See my instructions on using the timer (http://www.fixya.com/support/t1416237-timer_instructions_rangemaster_toledo) I hope that this is your problem and it will show you how to get the oven going again.
SOURCE: Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
SOURCE: t took the large oven door off my rangemaster
You should be able to lift the door, align the hinges into the slots.Then lower the door and allow the notched area of the hinge to fall into place. This may take a couple of tries to accomplish.
Testimonial: "thank you so much i'll try that."
