I'VE DOWNLOADED THE DLL ESCORT BUT IT NEEDS LICENSE KEY TO FIXE MY PROBLEMA. PLEASE I NEED A HELP
SOURCE: I want TTFSUB. GPD
That's the print spooler files for your printer. Just uninstall the printer and reinstall the print drivers using the included software.
Steps:
1) Go into Control Panel~Device Manager (Devices and Printers in Win 7)~right click on the HP printer and left click on Remove Device.
2) Reinstall the printer using the HP software that was included with the printer or go to the HP web site to download the software if you have lost the original disk.
That should do it.
SOURCE: i can't pay fee. i
Hello Pls tell me your printer is coming in ready mode or not if it comes in ready mode then reload the firmwere from hp.com,your problem will be resolved 100%
The missing dll SoundMAX.dll is the dynamic link library module of Staccato Systems SynthCore 3 Library software program.
The dll file as well as the included Staccato Systems SynthCore 3 Library program is produced by Staccato Systems.
SoundMAX.dll is an important component for the program and in the case it is corrupt or not found you can get Windows problem warnings similar to; "SoundMAX.dll is deleted" or "Staccato Systems SynthCore 3 Library failed to start because SoundMAX.dll is not found".
To fix the error, you need to replace the corrupted or missing SoundMAX.dll file with a working one.
The current version of dll file available on our site is 3.0.0.0 with a size of 1008 kb.
You may download the file for legally licensed software only.
You can download SoundMAX.dll for free by clicking the link below.
After you download the file, unzip it to Windows system directory ("Windows/System32" for
Windows XP, Vista, Windows 7). You can use Winzip or Winrar to extract files.
Press "Start" and select "Run".
Type CMD and press Enter.
Type regsvr32 *dllfilename* and press enter again.
Download SoundMAX.dll v3.0.0.0
Please note : No guarantees or warranties are given or implied.
Please download and install the file at your own risk.
Always take a backup of the original file in case something goes wrong
hope this helps
