Question about Holmes HM-7204 Cool Mist Humidifier Filter HWF100
I am looking for someone to show me where the filter goes in my inherited HM7204 coo mist humidifier. Does it take just one filter? Which side of the filter goes toward the middle of the machine and which faces out? Where does the filter go? S
  • 31 Answers
SOURCE:
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
New filter,still no mist and water level does not drop
make sure that the filter is VERY snug into the bottom of the humidifier, and that the tank is on correctly. We had the same problem :)
Jul 01, 2009 | Vicks V3100 1.2 Gallon Humidifier
Refugiop1@sbcglobal.net
first make sure the unit if off first then take the tank off and then tank the rest off of the base. once you take the part with the fan off the filter goes right in there. if you have any other questions please let me know.
Sep 13, 2008 | Holmes Products Cool Mist HM7204-U...
Humidifier
I have the evenflo cool mist humidifier, model # 758100. There should be a model number on the unit. As far as replacement filters, you can buy the Holmes humidifier filter, model # HWF62. It's compatible with Evenflo. I bought a 2-pk at Target for $15.99. Hope this helps.
Jan 09, 2008 | Evenflo Evaporative Cool Mist Humidifier
HM7204
Mine did the same, I cut one out of a piece of inner tube rubber. It has worked just fine for two seasons.
Dec 16, 2007 | Holmes Products Cool Mist HM7204-U...
Holmes HM-7204 Cool Mist Humidifier Filter HWF100 Logo
195 people viewed this question
Top Holmes Humidifiers Experts
donshafer
Paul
ray gallant
ray gallant
Are you a Holmes Humidifier Expert? Answer questions, earn points and help others
