Machine is less than two years old. Sounds like jet taking off on spin cycle. Unit was purchased Feb-Apr 2013 Has done so since 2-3 months after purchase. Thought this was normal for these. Now almost unbearable!
Unfortunately, you can't just replace the bearing because the bearing is located in the rear half of the outer tub. This is an extensive project but if you still feel like tackling it, then goto YouTube.com and type in, "How to change tub bearing on a whirlpool duet load washer. You can get a visual description for a DIYer. I hope this helps you out. Good luck to you.
I don't know your mechanical skills but there is
21 steps to disassemble
12 steps to replace the bearing
17 steps to reassemble the unit
Here is a list of tools required
Things You Will Need
Are you up to this project?? If you think you are let me know and I will post project step by step
Only fix is to replace inner and outer tubs and for the cost of that you could buy new machine.
