Question about Panasonic Audio Players & Recorders
Can a panasonic SB-WA930 Sub be linked with a special adapter to an Akai DHT300 DVD Receiver
Nothing cause the I dont even have the cord that comes with the subwoofer
    New Friend:
  • 20 Answers
If the 930 is similar to the 310 you might want to check this video out. Best I can tell they have the same connector in the back. If you a bit handy in fabricating a wire harness to fit the pins, or maybe pick a harness up off ebay and cut off the end that does not go to the sub, you probably can get it going. There are companies that will maike up "special adapters". Generally they are expensive.
https://www.youtube.com/watch?v=NPLot7tNZ7A
Posted on Nov 26, 2014
2 Suggested Answers
SOURCE:
Fuse keeps blowing up as power is turned on..help.
Greg, If the fuse keeps on blowing there is a problem with the internal amp. It was probaly caused buy a electrical power surge, Or a (********) up Sub patch cord,
Oct 04, 2012 | Athena AS-P4000 Subwoofer
My srm 450 dont automatically turn off when its not being used. Yesterday that same one started to smell burned and smoke coming out of it even though nothing was being played
Generally speaking this is a common issue with SRM-450 and it's due to opamp burned out inside electronic pcb, let me know further to improve help.
May 01, 2012 | Mackie SRM-450 System
Cant get my sub to work on my denon avr2808 and dont think it ever has it doesnt even work on the test signal
Hello
There are four possibilities that the subwoofer doesn't gives any aoutput. They are:
• Subwoofer's power not turned
on.
•The "Subwoofer" setting at
"Speaker configuration" is set to
"No".
•The subwoofer is not properly
connected.
•The subwoofer's volume is
turned off.
Go to its manual setupscreen, come to speaker setup, speaker confuguration, come towards Sub Woofer, select "Yes" and press OK.
Mar 21, 2011 | Denon AVR 2808Ci Receiver
Carver d12 subwoofer making humming sound
check your rca ground on the woof or the receiver you have a bad ground on one
Oct 09, 2009 | Electronics - Others
I hear noises when DD-10 is turned on.. even without signal to i
If it is a low level white noise, you may have some form of RF noise that is being picked up by the driver mounted servo system.
Then it could be something else as well.
Best to contact Velodyne to see about service for your unit.
Oct 03, 2009 | Velodyne DD-10 Subwoofer
Jbl pb10 subwoofer will not come on, that is the two lights in the front will not come even though it is plugged-in
1/ Check the power outlet, dont laugh i have been caught by this one
2/ Is the power cord removable (2 or 3 pin) if so then try another cord.
3/ If not check to see if there is a power switch in the vicinity of the cord
I know it sounds stupid however it does happen.
4/ Check to see if there is a fuse in the same area.
5/ If not you will have to remove the cover back, front, or bottom
to gain acess to the internal power supply, there should be a fuse in
the power supply and or a fuse in the amplifier circuit and or the speaker line.
binary6
Sep 16, 2009 | JBL PB10 Subwoofer
No sound from base speaker
(Please read the whole thing before opening anything)
Loose connections inside either the receiver or the subwoofer. Open the subwoofer case (the screen should pop off, if there is no screen there is usually some hidden screws somewhere) and see if there are any wires that have been separated. The problem with subwoofers (more common in car audio) is that they will vibrate so much that when you have something meant to have a lot of bass without the subwoofer and then you add the subwoofer to it, it's overpowering it which causes it to vibrate harder; seperating the cord that attaches the fabric of the speaker itself to the metal harness.
You can do one of 2 things:
1) Souder the wires back together using a heat sink.
2) Get allagator clips, cut them down pretty short and just extend the length of the wires a little bit giving it more bouncing room. Caution with this because if you dont cover the clips and they touch the metal frame, you will have no sound. Electric tape them once they're on.
If nothing is seperated, check the input jacks from the speaker box frame to the speaker itself. Loose connections are common for the crimp on kind.
Also a good idea: if you really (I mean really) want bass and you have no neighbors within a 1/4 mile radius of your house, have a friend who is getting rid of his car woofers to hook you up an AC outlet from the power source, and then use the red and white cables going into the amp to come from your receiver. I've seen this and it's great when watching a movie or playing games. Surrounding people hate it. (Wonder why?)
Jun 13, 2009 | Audio Players & Recorders
I turned my 15" L7 kicker and smoke started to come out the box
As stated before, knowing the impedance of your subwoofer would really help the situation. Either way the link I have provided is to your subwoofers manual (Incase you dont have it)
But since you have said it has smoked, if it still works I recommend turning the bass boost down (Bass boost causes alot of heat within the subwoofers voice coil and even within the amp itself and should never be maxed out.)
Here is a link to your manual for the subwoofer.
http://www.kicker.com/sites/default/files/SoloBaricL7Series.pdf
So as a solution to your issue, keep your bass boost turned down. You should almost never need it if you have tuned your amp correctly (You have a very serious subwoofer there)
Consider yourself lucky if your subwoofer is still working without issues.
Feb 09, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Annoying humming sound coming from subwoofer...
The humming sound usually comes from the DC supply that is not filtered. The a/c converted or changed to DC needs to be "cleaned", before going into the ckt. Usually the capacitor and resistor network go bad, maybe causing the fuse to open. Even if you replace it, u may still have the "humming" because the circuit is still bad.
If you know how to look at the capacitor, resistor,or coils AFTER the diodes & replace the damaged part, u should be good!
Mar 02, 2008 | Boston Acoustics MicroMedia Computer...
Sony AMP/Subwoofer Problem
It is probably the tweeter, inside the Sub. it's the small ceramic disk between the cone magnet, and the speaker. id this thing is cracked or broken, this will cause the problem. if this is not it, then it is a problem with something in the wiring, and the only way to rectify it is to buy a new sub. Sorry due :(
Jan 26, 2008 | Audio Players & Recorders
644 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
