Calling Amana customer service
Http://www.appliancepartspros.com/parts-for-amana-agds902e-p1131831n-e.html
They have some diagrams, offer manuals, parts, & how to videos
24/7 Customer Support
Amana + RangeAmana Range AGDS902E / P1131831N E Parts
Amana Range AGDS902E / P1131831N E Repair Parts
Start New Search
SHARE:
Chat wI need a wiring diagram or schematic for an Amana - app-logo-small.pngl class="h_mi">
Amana AGDS902E / P1131831N E
Click the diagram where you think your part is located
Most Popular Parts for Amana AGDS902E / P1131831N E
Sale Oven Igniter
(9) View Repair Video Top Burner Igniter
View RepaiI need a wiring diagram or schematic for an Amana - whirlpool-bracket-3801f656-51-ap4395315_01_th.jpgs.com/whirlpool-broil-pan-set-4396923-ap3837379.html"> Broil Pan Set
Bracket
( Sensor, Temperature
View Repair Video Module W/bracket
I need a wiring diagram or schematic for an Amana - whirlpool-assy-hinge-right-r0706011-ap4252510_01_th.jpgos.com/whirlpool-module-w-bracket-32020101-ap4041505.html#diy" target="_blank" rel="nofollow" >1) View Repair Video Oven Door Hinge, Left Side
I need a wiring diagram or schematic for an Amana - whirlpool-oven-igniter-786324-ap2934763_01_th.jpgpool-assy-hinge-right-r0706011-ap4252510.html" target="_blank" rel="nofollow" >Assy, Hinge Right
Download Manuals for Amana AGDS902E / P1131831N E Range-S/c S/i Ddraft Gas
- Owner's Manual
How to Troubleshoot and Repair Amana AGDS902E / P1131831N E
Real advice from real customers just like you
Do-It-Yourself Stories from Customers like You
Stephen F. bought this part
sale
Whirlpool Oven Igniter View Repair Video
Oven took long time to ignite and when it did it came on with noise Stephen F. • Star Junction, PA • June 20, 2014 My Repair & Advice I looked up oven igniter on line and watched video, very helpful, then called and a women was able
Easy Difficult
Repair Time Estimate
Less than 15 minutes
Corey B. bought this part
Whirlpool Bracket Needed anti tip plate Corey B. • Portland, OR • November 03, 2014 My Repair & Advice By moving the stove, installing with a few screws and sliding it back into place.
Was this review helpful to you?
Do-It-Yourself Rating
Easy Difficult
30-60 minutes
How-to Videos for Amana AGDS902E / P1131831N E
How to Replace Oven Igniter
How to Replace Top Burner Igniter
How to Replace Broil Pan Set
How to Replace Sensor, Temperature
SOURCE: STOVE TOP CONTINUOSLY SPARKS
Thrasher, Sorry I cant help with the diagram but one of your burner switches is grounding out. Each burner valve has a switch and one of them is finding it's way to ground, therefor the contstant clicking. Good luck on this deal...Catriver..post back.
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
SOURCE: I cannot seem to get
Gas ranges usually come with LP orifices attatched to them somewhere. In a small envelope or bag taped to the back or in the drawer they should be there. The natural orifices need to be removed and the LP ones installed. If the LP orifices are not installed properly you may get irratic flame and the flame can blacken the bottom of pans this needs to be remedied immediately due to the danger of the carbon monoxide being produced. I found good instructions for LP conversion at this site : www.peerlesspremier.com/faq-rangeconversion.htm
SOURCE: amana gas range trouble with starting
not a sensor, but more likely a bad oven ignitor(glow bar) its located under the ovne floor and mounted to the side ofthe bake bar. simple emough to unscrew and unplug, replacethepart yourself
SOURCE: gas top range ignition stuck on sparking
The switches that are causing the sparking are located under the knobs that you turn the burners on. Lift the knobs off and you should be able to see them.
If you have just cleaned the range the switches may have gotten wet. You can try to dry them out with the hair dryer, or just let them sit for 24 hours with the range unplugged. If they continue to spark after that you will need the switches replaced.
