It sounds like you've pre-programmed a certain sound that is usually only triggered by multiple keys into one key. The most efficient way to return to the way that you're searching for might be to perform a factory reset on your device. But you should back up any data into a USB stick before you perform the reset as all data in the Casio device will be reset.
Sounds like a lack of power from the external "wall wart" power supply. Is it the correct one that can supply enough current for a chord to be played? (a chord will play more notes at the same time & pull more power from the supply in order to make the sound(s)) If it's the correct power supply or one of the correct current rating check the cable & the connector both at the end of the cable & where it plugs into the keyboard. Perhaps the lead has been tugged accidentally? / Damaged in some way? Turn the volume down a little & see if that helps - that will confirm the power theory :-) Good Luck!
Hi, I’m repairing a casio cdp-220r for the same reason. The F3 key does not sound at all and some adjacent keys sound louder than the rest at normal play attack. I will have to replace the entire octave memebrane as I found that it was broken when I finally got access to it. See phot
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
More info. If you are chording on the left half of the keyboard, SOMETIMES they allocate or have the option to select a different voice for the part where chords are played. For these, you have to ALSO select a voice for that half of the keyboard. If you don't select a voice, then you would not have anything sounding.
NORMALLY "fingered" mode means that you have to "finger" the chord, that is, play all the notes of the chord. It sounds like it IS working as designed.
