Emerson MW8119SB Microwave Oven Logo
Posted on Nov 25, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When cooking a frozen dinner for 5 minutes at full power, everything is fine. When cooking a second frozen dinner for 3 minutes immediately following the first one, the microwave goes into the 70% co
I have tried pressing the stop and power level buttons to clear the power level back to 100% (default setting) and the problem persists
  • jamesjjv Nov 25, 2014
    my question was cut short. I meant to say it goes into 70% power setting on its own
Renwick B. Jeffrey
Level 2:
New Friend:
  • Expert 75 Answers
  • Posted on Nov 26, 2014
Renwick B. Jeffrey
Expert
Level 2:
New Friend:
Answers
75
Questions
Helped
10685
Points
195
Your circuit board has a small chip in it that allows the settings to be changed. The chip has gone bad. Usually any good electronics repair person can fix the problem. Ask your local dealer for a reference.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 12, 2009
SOURCE: I have Emerson Microwave #mw8999sv which has the
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Testimonial: "Thank you for finding the instruction manual for me. I now can set whatever time I wish on my microwave!"
Anonymous
  • 3 Answers
  • Posted on Apr 29, 2009
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 25, 2007
SOURCE: setting time
Sounds like a keypad problem. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by not using the fan when boiling on the stove top (for over the range models), direct spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. If you think you or a friend may want to take a look, please reply here and I can follow up with more targeted information.
1helpful
How do I cook an individual frozen pie in my Panasonic convection/grill/microwave
To cook an individual frozen pie in your Panasonic convection/grill/microwave, you can follow these steps:
Preheat the oven to 375°F.
Remove the pie from its packaging and place it on a microwave-safe plate.
Place the plate in the center of the microwave and close the door.
Press the "Convection" button on your microwave and set the temperature to 375°F.
Set the timer for 25 minutes.
Press "Start" to begin cooking.
After 25 minutes, check if the pie is cooked by inserting a toothpick into the center of the pie. If it comes out clean, your pie is ready! If not, continue cooking for another 5-10 minutes until it is fully cooked. This is a general guide and there might be variance with your particular device.
WMH1163XVD seems to no be on full power. Takes 1 minute to heat up a piece of bacon
1 minute to cook a piece of bacon sounds pretty fast, really.
Try this:
MICROWAVE HEATING POWER TEST
The following test will provide a suitably accurate measurement of the output power of any microwave oven. Variations or errors in performing this test will produce uncertain results. If the line voltage (from the electrical outlet) is low, the magnetron output will be correspondingly low.
Equipment needed:
- Microwave safe container with 1000 mL (1 Liter) gradation.
- Fahrenheit or centigrade thermometer
Procedure:
Pour exactly 1000 mL (1 Liter) of cool tap water into the container. Using the thermometer, stir the water, then measure and record the temperature. For accurate results the water should be about 60 degrees F (20 degrees C).
Place the container on the center of the oven cooking shelf (do not leave the thermometer in the container and remove any metal racks), and heat the water (at full power) for 63 seconds. Use the second hand of a watch, not the oven timer.
After the heating time is completed, immediately remove the container, stir the water, re-measure and record the temperature of the heated water.
Subtract the starting water temperature (step 2) from the ending water temperature (step 3) to obtain the temperature rise.
To determine the output power in watts, multiply the total temperature rise by a factor of 38.75 if you're using a Fahrenheit thermometer or by 70 if you're using a centigrade thermometer.
If the oven is grossly underheating or overheating, then you probably have a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
mini_manual_behind_grille_small.jpgdee77f7.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
2helpful
4answers
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
display.
Cook indicator.
Low power when cooking. Takes twice as long to cook a frozen dinner as what the package states
Check the power output. Most are adjustable. With the microwave on, and cooking something, see if it is on 100%. If not, adjust it with the keypad.
Regards, --W/D--
1helpful
I have a new microwave oven Model JVM1750SM1SS. Does this model allow me to use seconds rather than minutes. For instance can I place a frozen dinner roll in the oven for twenty seconds?
It should. Normally to cook 20 seconds you would pres COOK TIME - 2 - 0 - START.
You can download your owner's manual free.
We're happy to help and we appreciate your thoughtful rating of our answer.
Microwave re-started
The Start pad on the keypad may be starting to short. If so, a new keypad (membrane switch) would fix it.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's at
http://www.microwavedisplay.com/keypad_replacement.pdf
We have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
The part # needed is A64795790AP "membrane switch" for $46.88 available here.
Microwave Oven Panasonic NN-5560A
Chances are your Start key on your keypad has failed.
It is part # A64795790AP "MEMBRANE SWITCH", it runs $46.88 and you can find it here:
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
1helpful
2answers
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
