SOURCE: key fob wont work
the battery part just use a flat screwdriver, or if you are like my wife a butter knife, and pop off the back and go get a battery. You should not have to reprogram the remote. I just bought a 98 lincoln and the battery was dead in the remote also and all I did was replace the battery. hope this helps.
SOURCE: neither key fob is working to open the car with
open door. when alarm goes off put key in ignition and turn it on start car. this should disarm the factory alarm.
SOURCE: c240 mercedes key wont turn seems locked
I have a 2001 C240 with the same issue. I removed the positive battery cable from the battery and kept it off for 30 seconds then replaced it. Everything was reset and the key worked.
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
