I had brewed a cup of coffee. Heard a growl and saw the Kuerig discharging water and all of the lights were flashing. I unplugged it and the water stopped coming out, but when I plug it back in all th
I would start with the basics. Get the quick start manual and follow the instructions. If that does not work then the pump or controling circuirty has failed. I have attached a link for the quick start guide.
Sometimes Air gets trapped in the system.Unplug Maker, Remove Water Reservoir, Tip unit at about 45 degrees over the sink to partially drain. Place back on Counter, refill reservoir and replace on Maker. Plug it in and turn it on. make a couple of large cups of hot water then give it a try with coffee
The BEST way that I found to fix my Kuerig after the dreaded DESCALE sign came up . Very simple and it works. All that you need is a STRAIGHTENED OUT PAPER CLIP
1..Unplug the machine
.2. Take off the water tank
.3. Lay the machine on its back
4.open the handle as if you were going to put a Kcup in
5. You will see a metal prong shaped like an arrow head . .Using a flash light makes it much easier to see There is a hole on each side of the metal prong
6.. Stick the paper clip in and out and rub it around for about 15 seconds Do that to each hole
. 7.. Up right the machine , put the water tank back on - fill with water and plug in . After it heats up , the problem should be solved. I brewed about 10 cups of plain water to try to clear out the debris . Then back to my COFFEE :)
my kuerig has water come through the k cup when I close the top without pushing brew cup size and if it does let me make a selection it brews 1/4 of cup I have descaled it 4 times locked in the water reservoir cleaned the needles turned it on and off any other suggestions to try would be greatly appreciated thank you
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
It's time to descale your brewer. Run a full reservoir of pure white vinegar through, and then a full reservoir of water, "brewing" and dumping one cup at a time. You might have to do two reservoirs of vinegar if you've never rescaled it before.
