Lowrance Elite5x Color Fish Finder 102001 Logo
s
scott grace Posted on Nov 23, 2014
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
garcuda
Level 1:
  • Contributor 36 Answers
  • Posted on Nov 26, 2014
garcuda
Contributor
Level 1:
Answers
36
Questions
Helped
17499
Points
68
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
3 Related Answers
Anonymous
  • 214 Answers
  • Posted on Feb 11, 2009
SOURCE: brought a boat with lowrance x24 no manual with it
Here's a link where you can download the manual..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good luck & have fun. If this helps you plz rate this 'fixya' for me. Thank you kindly.
dacdiver
  • 9 Answers
  • Posted on Jun 24, 2009
SOURCE: lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Anonymous
  • 4 Answers
  • Posted on May 05, 2011
SOURCE: lowrance eagle fish strike 2000c
The owners manual for the Eagle/Lowrance Fish Strike 2000c http://www.retrevo.com/support/Eagle-2000C-GPS-manual/id/517ci960/t/2/
1helpful
My fish finder shutsdown or restarts when I start my main motor
are they drawing power from the same bat? it maybe that starting the motor drop the voltage the finder receives
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Hi. I"ve got a brand new elite 5hdi and been on for about 1 hour. does not want to lock in. import it from the states to Mozambique. please help
Hi Pieter
The problem here is that the unit has no idea where it is on the planet.
I think your best bet would be to reset the unit to factory defaults (page 11 of the owner's manual) and THEN use the setup wizard (page 6) to reinitialize the device.
Link to owner's manual provided below in case you or anyone else requires it.
Hope this helps and good luck!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
1helpful
How do I erase trails
http://www.lowrance.com/Global/Lowrance-images/backgrounds/lowrance_hds_background.jpg
Here is a link to the lowrance website to the elite 5 page where you can download a pdf file of your owners manual.
Go to your gps screen on your unit and press "menu" twice. Under the Chart heading you will find "waypoints, routes and trails" select this option and when you open it you will find a tab for trails this is where you will locate the options to delete your trails so they wont clutter your screen.
Lowrance eagle fish strike 2000c fishfinder/gps/plotter owners manual
2helpful
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
1helpful
Rl70c raymarine depth finder problem
fish finder transducer needs to be on before you boot your system. check your hsb cables and termination
Top Lowrance GPS Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
ADMIN Eric
ADMIN Eric
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
