If your printer has 3 colored ink cartridges, your cyan (blue) cartridge is empty. Replace it with a new one. If your printer has just one colored ink cartridge, the blue section of it is empty. Replace the cartridge with a new one. You'll find the correct cartridge (normally a number) in the owners manual and/or on the cartridge itself. See the owners manual for instructions on where the cartridges are located and how to replace them.
Hi there, No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show:"ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace. Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again. Hope this helps. Rate if it works. Thanks
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. Try to unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace.
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Hi, Your Cyan cartridge is empty and need replacement. Maybe you can clean head of Cyan cartridge with alcohol but symptoms are the empty cartridge! Good luck.
