Samsung HLT6187SAX 61" DLP HDTV Logo
James Williams Posted on Nov 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony 61 dlp the lamp light flashes 16 times then the timer,lamp, and standby flashes 3 times the is cycles and lamp light flashes 16 times again.
Replaced lamp
Jack South
Level 2:
Scholar:
  • Expert 195 Answers
  • Posted on Nov 26, 2014
Jack South
Expert
Level 2:
Scholar:
Answers
195
Questions
0
Helped
35514
Points
350
The lamp is not firing. The set shuts down after 3 attempts to strike the lamp. Try another lamp.
5 Related Answers
Anonymous
  • 4402 Answers
  • Posted on Jan 16, 2008
SOURCE: Replaced lamp still not working
Power issues (Tv True True (``````````` (``````````` 0 95250 95250 clip_image002.gif not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung True True (``````````` (``````````` 0 95250 95250 clip_image002.gif is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 26, 2008
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Anonymous
  • Posted on Sep 27, 2008
SOURCE: Samsung DLP will not turn on
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first. The thing is the lamp will not turn on if there is a problem with one of the other two parts. TRUST me ... I've replaced all three parts just to find out it was only the cooling fan. (at least I have another lamp handy when the new one goes out). The motor on the cooling fan is too small for such a big fan so I would definately try it first. It's a big problem with the DLP tvs. Hope this helps.
Anonymous
  • 51 Answers
  • Posted on Dec 27, 2008
SOURCE: 3 blinking lights - Samsung DLP
Remove your new bulb and examine the connector carefully. The inexpensive replacement bulbs tend to arc and ruin your $700 ballast; sad to say. If everything looks good, make sure the interlock switch on the bulb cover opening is engaging. It won't fire up if it thinks that door is open.
electroman
  • 1039 Answers
  • Posted on May 02, 2009
SOURCE: Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
Why does my samsung 61" DLP Standby/Temp and Lamp light flashes 29
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Looking for technical help for Samsung 61" 1080p 120Hz Slim-Depth LED Engine DLP television . I have sound but no picture. 3 flashing lights on from of panel; timer, lam, and standby/temp
Hope you got helpful info from our expert to solve your tv issue, if you still need further help, let me know to assist you further along with info what actions have been taken to fix the problem.
Thanks.
Tv keeps shutting itself off. the power button will then begin flashing in green lighting the words"timer and lamp' and in red letters the word "standby". i can press the power button to turn the tv back...
The first thing to try is a new lamp. There should be an orange or red tag on the left side of your set that has the lamp number on it. The number will look something likr BP96-01434A. It probably won't be this exact number but will have that sort of format. Google "DLP lamp" and you'll find numerous sites that sell lamps. Shop around for the best price.
2answers
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Live Chat Session
i have 3 lights blinking on my samsung dlp...the lamp light flashes a few times then timer and standby/temp flash....can any1 help
No sound or pix
3 times flash of standby light shows that Lamp Cover is not mounted properly after replacement of Lamp.
Please fix lamp cover properly because cover has to press protection switch in circuit.
1helpful
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
1helpful
2answers
SONY GRAND WEGA
I have a KDF60XS955. When I power it on, the fan comes on, the standby light flashes green several times, the lamp comes on and the standby light goes to solid green. This lasts for less than 5 seconds then the lamp goes out, followed by ~30 green standby flashes, the lamp coming on with the solid green standby light for about 5 seconds then shuts off the lamp again. I can hear/feel the fan running the enitre time. This cycle continues endlessly. Please help!
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
